Alright, new gears arrived and are pressed onto the shaft. zx50 pulley on the way. Once that arrives this thing will come together quick and i will hopefully have the chance to fire it up over the weekend. So the question pops up what to jet the carb with.
-Polini Corsa
-Ct mani with 21mm OKO
And what pipe to run? Would it be okay to fire it up with the stock pipe or do i dare fire it up with this beast that is too big?
I probably wont be driving it around but would love to get some heat cycles in and make sure everything is running well and nothing is rubbing
Complete NOOB, sorry dudes 1984 Iowa Spreedio aka "Hammy"
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
There isn't a much room once you get the belt in there but i think the polini for ruck pulley along with the zx50 rear pulley pulls the belt enough so it wont hit the case. Plus lots of dremel grinding for insurance
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
When swapping connectors on the elite engine so it will work with the spree is it okay if i just electric tape the wires that are supposed to go to the starter? Like just wrap some around each end and keep them seperate from anything for a bit?
The starter wont work anyways cause of the zx drive boss. Can this be a temp fix til i can get some bigger bullet connectors?
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Tires' Actual sizes vary by brand, sometines by a lot.
A Michelin S1 required a lot os case shaving by the exhaust mount so as not to rub.
. A 90/90 is a much safer choice.
Petrock's 1984 Spree wrote:Same deal with the oil level sensor plugs on the wiring harness. Can i just electrical tape those as well?
Yes, you can tape them off individually so they don't make contact with anything. Does not have to be electrical tape, the handy man's tool always works.
There is another wire I'm not sure about. It's from the dio engine bundle and it's a single red wire with a white stripe. It's not the one from the starter, it's by itself. What is this wire for?
I've looked at the wiring diagram but I can't read it because it's way too small
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Petrock's 1984 Spree wrote:There is another wire I'm not sure about. It's from the dio engine bundle and it's a single red wire with a white stripe. It's not the one from the starter, it's by itself. What is this wire for?
The only red wire with a white stripe on 2 of my elites is in the harness connector that goes to starter relay.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
I'll take a pic of it then because it doesn't make any sense to me.
And there is the other green wire in the spree harness. It's the ground wire to the magnet on the stator. Spree magnets have two wires and the elite stator only has one so I guess I'm just taping that one off individually too
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Okay these are the wires I'm talking about. Here are the two that go to the starter. They are the green wire and the red with a white stripe wire.These are on the Elite wire bundle coming from the engine P1010953 by jpetrak, on Flickr
Now here is the odd ball wire that makes no sense. It is also a red wire with a white stripe and has some wierd connector on it. It is also coming from the Elite engine bundle. Kinda fuzzy P1010949 by jpetrak, on Flickr P1010951 by jpetrak, on Flickr
What does this wire do?
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
