Checkin in, first post... here at least
Chicago Ben
Re: Checkin in, first post... here at least
Post by Chicago Ben »
any idea what size I am shooting for with these upgrades?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
Making some headway... mounted engine (W00t!!!) , installed front fender, and leg shield/glovebox. Did all the wiring including jap tail. Installed throttle cable to carb. Installed vacuum line to intake manifold. I dremeled the shroud so the spark cap could fit.
I want to fire this bad boy up to see how we are doing but I need a new main fuel hose. Does anybody know what size hose I need for this?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
fightingplankton
Post by fightingplankton »
looks great
'86 spree
'86 aero50
'83 aero80
Chicago Ben
so...
Went to advanced auto parts and got a new fuel line. Tried starting it up and kickstart was sticking. Removed it, grinded a lot more of the inside down with a dremel (powder coating added too much material) , installed it back and finally got this thing running.
Here is a movie... you can see my temp gauge is flashing 278.. that was the max temp I hit just driving it up and down the alley way here behind my place... I'm going to need some serious tuning help
http://youtu.be/KBGFv3OLbAQ
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
fastplastic
Post by fastplastic »
your not in that much trouble but a quick pm to backa or wheelman once you get it broke in wouldn't hurt.....
Chicago Ben
so ran the bike again today. I have the bike idle-ing just fine. I definitely need to rejet my main though. I have strong power when I open the throttle until about 1/4 then it just BOGGGGGGG's out like its getting all air and no fuel. I maxed out at 301 degrees F probably around 30 mph and shut her down today
Time to order some jets from treatland
Also I'm leaking fuel from my main fuel line at the carb nipple, thank god I have my crank cover on-fire waiting to happen. Having a hard time getting that hose on and my hose clamp all smashed in between the carb and outside of hose
mehh....
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
That is how my 86cc ran .....with that filter on. :wink:
What is the jetting now?
Chicago Ben
Trafficjamz wrote:That is how my 86cc ran .....with that filter on. :wink:
Ha I knew someone was going to chime in about that filter. I'm at 50 pilot and 155 main. I just ordered a set from scooter assasins on fleabay which will give me 158, 160, 165, 170, 175, 180
I'm thinking one step at a time, shouldn't my ideal temp range be under 300?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
KingJeff801
Post by KingJeff801 »
Not sure on the 86cc but my 72cc corsa sees 325 to 350 temps normally with no concern
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
KingJeff801
and by the way your white kicker cover..............I can't get over how bad * it looks!!!!!!!!!!!
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Chicago Ben
KingJeff801 wrote:Not sure on the 86cc but my 72cc corsa sees 325 to 350 temps normally with no concern
That's good to know thank you I was getting worried at 300
KingJeff801 wrote:and by the way your white kicker cover..............I can't get over how bad * it looks!!!!!!!!!!!
Haha yeah it turned out pretty cool eh?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
... this is going to sound ridiculous
are my floats installed correctly or are they upside down?
I'm up to a 160 main now and I still BOGGGGGGGGGGG at like 1/5 throttle I feel like I need to raise the needle, I got up to about 325f today
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
The floats are in right, it pretty d*** hard to install them upside down.
However, your float level is set way high which may explain the jetting problems your are having.
Chicago Ben
I assume you are referring to the actual fuel level we see there, how can that be adjusted? I remember reading through posts where an individual had to bend their floats back down, same situation here?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
found trafficjamz's picture
is this what you are referring to ?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
