Page 16 of 21
Re: Checkin in, first post... here at least
Posted: Sat Jun 25, 2011 7:48 pm
by Chicago Ben
any idea what size I am shooting for with these upgrades?
Posted: Sun Jun 26, 2011 12:57 pm
by Chicago Ben
Making some headway... mounted engine (W00t!!!) , installed front fender, and leg shield/glovebox. Did all the wiring including jap tail. Installed throttle cable to carb. Installed vacuum line to intake manifold. I dremeled the shroud so the spark cap could fit.
I want to fire this bad boy up to see how we are doing but I need a new main fuel hose. Does anybody know what size hose I need for this?
Posted: Sun Jun 26, 2011 3:34 pm
by fightingplankton
looks great
Posted: Mon Jun 27, 2011 8:36 am
by Chicago Ben
so...
Went to advanced auto parts and got a new fuel line. Tried starting it up and kickstart was sticking. Removed it, grinded a lot more of the inside down with a dremel (powder coating added too much material) , installed it back and finally got this thing running.
Here is a movie... you can see my temp gauge is flashing 278.. that was the max temp I hit just driving it up and down the alley way here behind my place... I'm going to need some serious tuning help
http://youtu.be/KBGFv3OLbAQ
Posted: Mon Jun 27, 2011 4:09 pm
by fastplastic
your not in that much trouble but a quick pm to backa or wheelman once you get it broke in wouldn't hurt.....
Posted: Tue Jun 28, 2011 10:43 pm
by Chicago Ben
so ran the bike again today. I have the bike idle-ing just fine. I definitely need to rejet my main though. I have strong power when I open the throttle until about 1/4 then it just BOGGGGGGG's out like its getting all air and no fuel. I maxed out at 301 degrees F probably around 30 mph and shut her down today
Time to order some jets from treatland
Also I'm leaking fuel from my main fuel line at the carb nipple, thank god I have my crank cover on-fire waiting to happen. Having a hard time getting that hose on and my hose clamp all smashed in between the carb and outside of hose
mehh....
Posted: Tue Jun 28, 2011 10:53 pm
by Trafficjamz
That is how my 86cc ran .....with that filter on. :wink:
What is the jetting now?
Posted: Tue Jun 28, 2011 11:27 pm
by Chicago Ben
Trafficjamz wrote:That is how my 86cc ran .....with that filter on. :wink:
Ha I knew someone was going to chime in about that filter. I'm at 50 pilot and 155 main. I just ordered a set from scooter assasins on fleabay which will give me 158, 160, 165, 170, 175, 180
I'm thinking one step at a time, shouldn't my ideal temp range be under 300?
Posted: Tue Jun 28, 2011 11:42 pm
by KingJeff801
Not sure on the 86cc but my 72cc corsa sees 325 to 350 temps normally with no concern
Posted: Tue Jun 28, 2011 11:43 pm
by KingJeff801
and by the way your white kicker cover..............I can't get over how bad * it looks!!!!!!!!!!!
Posted: Wed Jun 29, 2011 8:50 am
by Chicago Ben
KingJeff801 wrote:Not sure on the 86cc but my 72cc corsa sees 325 to 350 temps normally with no concern
That's good to know thank you I was getting worried at 300
KingJeff801 wrote:and by the way your white kicker cover..............I can't get over how bad * it looks!!!!!!!!!!!
Haha yeah it turned out pretty cool eh?
Posted: Fri Jul 08, 2011 11:47 pm
by Chicago Ben
... this is going to sound ridiculous
are my floats installed correctly or are they upside down?
I'm up to a 160 main now and I still BOGGGGGGGGGGG at like 1/5 throttle I feel like I need to raise the needle, I got up to about 325f today
Posted: Sat Jul 09, 2011 2:07 am
The floats are in right, it pretty d*** hard to install them upside down.
However, your float level is set way high which may explain the jetting problems your are having.
Posted: Sat Jul 09, 2011 8:44 am
by Chicago Ben
I assume you are referring to the actual fuel level we see there, how can that be adjusted? I remember reading through posts where an individual had to bend their floats back down, same situation here?
Posted: Sat Jul 09, 2011 9:16 am
by Chicago Ben
found trafficjamz's picture
is this what you are referring to ?
