AF16E Spree swap, summer project!
- Petrock's 1984 Spree
Re: AF16E Spree swap, summer project!
I thought the bystarter was 2 wire
A green and a yellow
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
- Trafficjamz
These wires are for the starter, but do not go to the starter, They get attached to the spree wire harness.
This wire goes to the starter motor.
Correct the green wire and red with a white strip wire are coming from the elite engine and do get cOnnected to the spree harness. I just tapped them off for now because I don't have big enough connectors
That odd ball wire is coming from the elite engine as well. So I gets connected back to the starter motor? Can I just tape that off seeing as my electric start won't work for the time being due to the zx trans mod?
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
- Trafficjamz
Petrock's 1984 Spree wrote:Correct the green wire and red with a white strip wire are coming from the elite engine and do get cOnnected to the spree harness. I just tapped them off for now because I don't have big enough connectors
No real reason to tape it. It will not do any harm if left alone.
It's just my way of checking it off the list.
Alright well trying to wire this up with a fractured vertbrae didn't work. I got halfway and then everything locked up. So 4 steroid shots in the spine later and I'll be good to go at it again tomoro!
This is where a lift would be a life saver
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Have a friend throw it up on a card table for you. Been there with back problems and I've found that works best. Tall enough to use a roller stool to swing around side to side but short enough you can reach the controls on the handlebars.Petrock's 1984 Spree wrote: This is where a lift would be a life saver
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
The v8 tyhpoon and exhaust gaskets arrived today!
So once I get the wiring finished I can fire it up. Which brings up now where to jet it. I'm guessing I should jet on the rich side so how does 43, 140 sound?
21mm carb with CT mani
k&n metal mesh air filter
V8 Typhoon exhaust
V8 Typhoon exhaust
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
- Trafficjamz
Petrock's 1984 Spree wrote:The v8 tyhpoon and exhaust gaskets arrived today!
V8 Typhoon exhaust
way too rich
try 120 main and 48 pilot
- fastplastic
that still might be a lil right but a good starting point
Baka has me starting at 115
I'll probably use a 45
Once these jets come in I'll be in business!
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Got it running now!
P1010974 by jpetrak, on Flickr
P1010975 by jpetrak, on Flickr
I assume this temp is alright for a scoot with this set up all warmed up without the shrouds on it
P1010980 by jpetrak, on Flickr
How does it sound? Anything jump out at anyone that might needed to be adjusted slightly or is it pretty good for some heat cycles?
http://www.flickr.com/photos/58369736@N06/5784057962/
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
- SpreeMadness520
P.S. The front forks look SWEET
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
I was gonna make my own custom gas tank to fit the rear rack so i hacked up my oil tank to get the sensor out so i could use that as my reserve tank gaugeSpreeMadness520 wrote:, Look at my pic for the oil reserve tank, I put spacers for the tail light so it doesnt rub. Looks good too.
Need to get those washers too.
Haha oh yes, the forks are worth every bit of effort to fit em on there
I let it idle now for 10-15 minutes and the temp climbed slowly up to 330 F before i shut it off.
Isn't a little toasty just for idle? Maybe a little lean?
Still have the shrouds off it though so maybe not
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
- SpreeMadness520
I will eventually put the elite forks on, But I need to get the bbk and other extremities first.
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
