Spree Engine Swap: Honda Elite CH80 onto Spree
Re: Spree Engine Swap: Honda Elite CH80 onto Spree
Heya tyler, nice job! valve lapping is fun! I use a vice to hold the head so I can just spin the tool on top.
Also are you planing on raising the compression or lowering it? Removing material from the combustion area for flow is great but also makes a larger chamber, ie lower compression.
- paulpauly7
scroll thru the pages lovemyhonda he has had the head weld filled and smoothed
Trying to raise the compression by filling the dead space of the combustion chamber with weld. The ruckus guys have been doing it so I'm trying it on the ch80. The stock compression of the ch80 is 9.3:1 so a little higher should be doable.LoveMyHonda wrote:Heya tyler, nice job! valve lapping is fun! I use a vice to hold the head so I can just spin the tool on top.
That so awesome!
nice work tyler. i have used a drill on stem side of valve. for a old chevy i had just to speed things up. worked good.
tyler you have some nice builds. the 125 spree, the 80 spree. what's next? the 250cc spree. that would be sick speed.
Thanks, my next project will be call the Honda Centi-Spree. Three sprees welded together in a row, each exhaust feeding back to the next engine.ped wrote:nice work tyler. i have used a drill on stem side of valve. for a old chevy i had just to speed things up. worked good.
If I were to get a hold of a larger 150cc-250cc engine I wouldn't swap it onto a spree. But build a side cart with the engine hidden inside.
I think this ch80 spree is my last swapped spree, I'd like to buy a ruckus or maybe build up a elite 50 someday. I did just buy a crappy parts spree for $60, probably wasn't worth that but I have enough stock parts to piece it together.
- swimmingfree
Tyler VR did you do a compression test on motor before you did the welding on it??? i wood like to no what it is now after all the work you have done on the dead..
I didn't, my compression tester isn't very accurate. I've read about others checking the volume of the combustion chamber by filling it with water and using a measurement syringe to check it.swimmingfree wrote:Tyler VR did you do a compression test on motor before you did the welding on it??? i wood like to no what it is now after all the work you have done on the dead..
