Checkin in, first post... here at least
evilone
Re: Checkin in, first post... here at least
Post by evilone »
Chicago Ben wrote:is this what you are referring to ?
Yes
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Mystic
Post by Mystic »
If you dont have the special tool that measures the float level you can take a piece of cardboard and cut it to fit over the float |---| the arms should touch the carb body on each side and measure for the height the manual says it should be, tilt the carb sorta sideways to make the float rest lightly on the needle valve top spring. if your measurement on the cardboard is right and your float is right it should match up, if not bend the tab on the float till it matches the correct measurement on your homemade tool
Great idea Mystic. If'n you can write up that float measure tool design and post pics and specs, it'll be in Tech Docs for posterior-ity.
Chicago Ben
Post by Chicago Ben »
mystic its kind of hard to follow what you are describing...
if you guys were to draw a line on my float bowl marking max fuel fill height, where would that be?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Mystic
Post by Mystic »
sure I will make one and post pics :D its pretty simple once you get the idea then you can make one for any carberator :D
Yes, but I do not remember the measurement length.
Chicago Ben
You guys can see where the true fill level is here on the video:
here is the link: http://youtu.be/wv6mjgHrt5g
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
I was watching a few videos on youtube about float adjustment
So if I have the carb off the bike and drained...
1) Flip it over so the floats are just hitting the spring
2) Measure the distance from the top of the float (really the bottom when its right side up) to the level surface where the float bowl mates , that should read 26mm?
can anyone confirm this to be the correct procedure?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Mystic
Post by Mystic »
viewtopic.php?f=3&t=19885&p=171241#p171241
check out this thread Ben to adjust your float level without the special tool :D
Chicago Ben
Mystic wrote:viewtopic.php?f=3&t=19885&p=171241#p171241
dang mystic what a great write up, thank you for that. 2 questions
your last picture... seen here
1) based off of what you wrote, if the floats were just lightly sitting on the spring, shouldn't the floats need to come up a tad in that picture to hit your line of 12.2mm? right?
2) where can I find what level I should be at if I have an aftermarket carb?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Mystic
Post by Mystic »
yea hahah that carb is one I bought at an auction it was the cleanest and easiest to get to, its a yinba carb for a go kart i think. I dont know what the float level is supposed to be on it probably 12mm 12.2mm is the spec for the sa50 i was using as an example. If the carb were the sa50 carb the bottom would line up evenly with my marks :D I am not sure what the level is supposed to be for your OKO sorry
Yes, that measurement is useless on your OKO carb.
Chicago Ben
Bear45-70 wrote:Yes, that measurement is useless on your OKO carb.
I understand that , just wondering where I would get this measurement from?
The box the OKO carb came in is no help either
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
dun rite
Post by dun rite »
a quick search online says. 19mm from carb base to top of float ( bottom actually) the pic showed a 28mm oko, another page said same for a 21mm. seems like 19mm is the oko standard.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
I used to have a link to the OKO service manual but lost it in the last crash of my computer because I was stupid and didn't back anything up for about 6 months on my standalone 2 terabit backup hard drive. Image
