cruzingratiot
Post by cruzingratiot »
johnny248 wrote:Is the intake you installed?
http://scootertuning.ca/en/intakes/1600 ... rsize.html
If so, I can see that it doesn't do the "out and up" thing that my Naraku (at the ct's do). I wonder what actual difference in performance the two different styles provides?
Stage 6 intake only have about 100 miles on it
I like the way it fits closer to the motor
performance felt like better mid power
Stage 6 Oversize Valve intake #S6-3217500
johnny248 wrote:
1man8scoots wrote:I just sent a 120 miles rear turn signal housing to johnny248 and I don't believe he's using the lens. I sent it to him for shipping so maybe he could do the same for you if you want it.
What part does he need? Just the turn signal lense? I have one, but I though he had JDM tail light setup?
Let me know if I can help!
just wating on front left turn signal housing( not lens ) is is on its way
Donate Life
http://www.donatelife.net/
Thank You
johnny248
Post by johnny248 »
I have an extra front housing. d***, I would have sent it over to you.
~UNDER CONSTRUCTiON~
cruzingratiot
future changes this hopefully summer 18x41 and 18x39
to try them out and see what happens
now that it has better brakes
ill feel safer trying to get it to go faster
the 18x41 took a while to get
Thanks Scooter swap shop (graphite9)
Donate Life
Thank You
cruzingratiot
back together
right around sunset went for a short ride
good weather called for tomorrow
Donate Life
Thank You
curtis966
Post by curtis966 »
Looks great man!
Xxbeejay45xx
Post by Xxbeejay45xx »
I swear this is the prettiest Mystic Purple Elite out there! All show and definitely all GO!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
ped
Post by ped »
it does look good. ready for summer :peace:
cruzingratiot
Thanks for all the compliments and comments
I am not done modding this scooter
but i really like the way it looks and performs to this point
Remember
Danger never takes a vacation
Ride safe
Paul
Donate Life
Thank You
cruzingratiot
a look back from the start to now
April 2015
EDIT 4-26-2015
6,205 miles
replaced variator and drive belt
Donate Life
Thank You
cruzingratiot
25.5 grams in new variator
the old one had a slight grive down low
new belt
7.97-1 gears installed with early 2 bearing cover
new red contra spring
new springs in polini clutch blue springs 245.072
its spinning 11,000 + rpm
put in a 45 pilot
this is over a couple of days
running great
turning 9,000 - 9,500 rpm at 40 mph
and pulls really good from 40
more to come
Donate Life
Thank You
johnny248
Post by johnny248 »
I got to check this thing out today. It is BAD! Super sweet scooter, and it sounds awesome. The new front end he put on is beautiful.
curtis966
Post by curtis966 »
He used a mill not a drill and I believe you need to take about .075 inches off of it and you will clear the shoes and not be to far and hit your splines with the nut.
curtis966
Post by curtis966 »
Yeah any machine shop will be able to do it for you and should leave you a clean flush face.
cruzingratiot
Re: 2000 Mystic Purple Elite build (70.1 mph)
i have a milling machine in my garage
that is how i did it
sorry for delay in responce
computer broke surfing on smart tv is not fun
it is slowwww
Paul
codename47 wrote:
cruzingratiot wrote:your measurements may very
decided to finish this today
was shooting for .080 of a inch ( even though I measured it as .070)
but wound up milling .100 thousand of a inch
wouldn't take any more than that it
is within .020 of hitting the big threads on clutch (contra spring ) assembly
upon further investigation I realized
that I didn't need to drill out the relief on the splines
hopefully my posts on this build will help others
that is why I try to get into detailed explanations of what I am doing
along with helping me out because the older I get the more I forget
Paul Jug
I only have a postal ounce scale it weighed 2 ounces heaver than stock bell
which is about about 56 grams
according to manufacture the Naraku i weighs 0.63 kg
0.63kg = 22.223oz
yea I know I have the filter tube from carb to air box off
I took the carb off to replace fuel lines
the 13 year old fuel lines were starting to scare me
this picture just to show you what the finished job looks like on the Elite
how did you end up drilling this down? you linked to a video of the, other naruku bell, and thats the one I got. and i measured, that exactly how much higher than stock bell drive boss measures. it was about .75 inches higher than the stock. and i measured the stock at that .685" or .. whatever it was, that height. the other naruku bell measures that much higher too.
anyway, how did you end up drilling the end down? i mean, how did you drill what tools did you use, to drill down the clutch bell to get it to fit over the pads on the clutch?
Donate Life
Thank You
johnny248
Post by johnny248 »
Everyone should see this scooter. It's absolutely beautiful. The wind jammer pipe is the best looking pipe ice ever seen on anything. The build quality is unreal. The wds are as perfect as could ever be, and it runs like nothing ive seen. Sounds like a factory 125 mx bike. Revs ip, sits right in the power and and the cvt just sits right in the power all the way through . No hesitation or fluctuation or anything. It probably is as good as any scooter could be. Id love to own this thing. CG definitely has built some awesome bikes.
