Page 18 of 20
Re: AF16E Spree swap, summer project!
Posted: Sun Jul 17, 2011 11:49 pm
by natek
read through the entire thing..... kinda freaked me out lol. is there another swap thread that i'm missing on this sight? everyone keeps saying it's an easy swap but that seemed a lil more involved than originally depicted. still wonna do it, just wonna stream line it and remove room for my error.
Posted: Mon Jul 18, 2011 12:07 am
by bakaracer
the noise mostly comes from the carb. if you can get an airbox on that carb, it will quiet down the engine noise alot. if you want to run thge stock exhaust on the corsa, it will be ok. just dont expect high rpm's out of the setup but the torque will be great. you will be down about 2k rpm as the stock pipe will limit it to around 8500 which is still good.
Posted: Mon Jul 18, 2011 7:37 am
by Spreetard
natek wrote:read through the entire thing..... kinda freaked me out lol. is there another swap thread that i'm missing on this sight? everyone keeps saying it's an easy swap but that seemed a lil more involved than originally depicted. still wonna do it, just wonna stream line it and remove room for my error.
Um, yeah.... this build takes the difficult method more oft than the simple. The af16 motor mount can be modified to fit the spree frame without the whole "let's hack apart an elete frame" method. It's so much simpler that many of us recoiled in horror at the different "method" employed on this build. Somebody find this dude the link he wants, I'm at work and have stuff to do! :lol:
Posted: Mon Jul 18, 2011 11:07 am
by natek
that would be swell!!!!! thanks
something that i cant seem to find (maybe in the link). do you have to relocate the shock mount? i've heard both. someone said an offest shock would work but no one has told which one. the ruckus shock was mentioned and i can experiment with that since i have one, but there has to be another option.
Posted: Mon Jul 18, 2011 11:16 am
by Spreetard
The shock mount needs moved back a bit.
I know there's got to be a more detailed thread than mine, but here it is ... viewtopic.php?f=16&t=18402 My thread is not the most detailed, though :oops:
I'll try to find a better link when I'm not at work...
Posted: Mon Jul 18, 2011 12:20 pm
by Mystic
richdavidson34 here on the forum fabricates custom shock mounts for the spree/af16 engine swap, all that is required is 4 holes drilled to bolt it on, can be used with the spree shock or the elite shock :D he is a super guy, fast shipment, and perfect welds :D
Posted: Mon Jul 18, 2011 11:26 pm
by natek
Mystic wrote:richdavidson34 here on the forum fabricates custom shock mounts for the spree/af16 engine swap, all that is required is 4 holes drilled to bolt it on, can be used with the spree shock or the elite shock :D he is a super guy, fast shipment, and perfect welds :D
That's the stuff I'm looking for!!!!! I know that stuff is on this sight but I just can't find it!
Posted: Sat Jul 23, 2011 6:05 am
by sprite2011
He is making one for me if you are looking for a bracket. I made my own but if you want you can have the bracket he is currently making just pm him.
Sprite
Posted: Sat Jul 23, 2011 10:07 am
by natek
sprite2011 wrote:He is making one for me if you are looking for a bracket. I made my own but if you want you can have the bracket he is currently making just pm him.
Sprite
i pm'd him like 2 weeks ago and got no response.
Posted: Wed Aug 10, 2011 10:41 pm
by Petrock's 1984 Spree
Wow its been way too long! But after multiple problems its finally running the way it should! At least i hope :confused:
Settings are as follows
42, 103
Clip on the needle in the middle
#9 Plug
I know its lean but its not four stroking any more and HAULS A**!! :naughty: :naughty: :smile:
Posted: Sat Aug 13, 2011 11:56 am
New settings, it was bogging and losing power right around 30-35
40, 103
Clip 1 up from middle
B9HS plug
Although now there is another problem. When its cooling down at a stop light it'll drop from around 290 to 260. Then when i try to take off again it will bog and lose power. I have to rev it a couple times before it will want to take off again. Whats the deal with that?
Posted: Sat Aug 13, 2011 12:35 pm
by bakaracer
to lean. put a that 42 or 45 pilot back in.
Posted: Sat Aug 13, 2011 5:56 pm
I put the 42 back in, but haven't gotten the chance to see if it fixes the problem. I was scared off by the cylinder heads temps reading over 330F at around 35 :surprise:
Going to try the 105 main and see what happens
Posted: Sat Aug 13, 2011 9:19 pm
I like the temps better with the 105, although very mild signs of bogging and loss of power happen around 1/2 throttle once again. Back to the 103 :sad:
I dont like the temps with it, so im gonna bump the pilot up to a 45 to see if that'll cool it off a bit more
Posted: Sun Aug 14, 2011 3:07 am
by devenex
If your having problems with partial throttle then try adjusting the needle setting before messing with the jet.
