My First Spree Swap (Aero NH125)
Re: My First Spree Swap (Aero NH125)
Incredibly tasteful attention to detail. I love the paint and Power Bulge. So how hard is it to strip the saddle and re-foam?
is that a go-kart tank ?
ped wrote:Hi Tyler.
What a SWEET scooter.
You can run that scooter for days! No worries.![]()
Thanks guys! The seat will probably be redone at some point or maybe I'll just make another with a pre made red seat cover off ebay.Wheelman-111 wrote:Greetings:
Yup, 1 gallon aluminum go kart gas tank off ebay. It's linked together with the stock tank, both have manual shutoff valves. I considered buying the round spun type tanks but it would have stuck out as wide as the rear turn signals. Now I can ride my spree for more than 25 miles without stopping for fuel.motormike wrote:is that a go-kart tank ?
This whip is really start to stand out, proud.
If "favorite builder" was a poll, my vote is Tyler VR.
trafficjamz a strong second.
Thanks Mike!motormike wrote:This whip is really start to stand out, proud.
- R1Titan911
Going back to your painting phase. Did you black your floor board then mask it for the white? Or do the white first and mask for the black? What black did you use? Satin? I thinking of the same pattern but maybe wrinkle or liner paint on the flats for your feet.
87' Spree: "Victoria's Spreecret"
78' Express:
78' Express:
I used a factory black colored floorboard, shined up the foot area and masked it off before painting. I would guess no paint wouldn't be durable enough to last on the area your feet rest, it would eventually chip off. I had a thought of sanding off the bumps and putting down skateboard grip tape.R1Titan911 wrote:Going back to your painting phase. Did you black your floor board then mask it for the white? Or do the white first and mask for the black? What black did you use? Satin? I thinking of the same pattern but maybe wrinkle or liner paint on the flats for your feet.
- R1Titan911
When my Elite grows up ,he wants to be Tyler's bada$$ spree
Tyler! Where can I get one of those S3XY Speedometer insert replacements? I was trolling through your photobucket page and almost fell off my chair when I saw them...I NEED!!!! Are they paper? Translucent Plastic? How do they look at night? NEEED ONE!!
Thanks for the comments guys!
You could try printing this out and seeing if it's the right size, might have have to change printer settings to actual size or save it and resize.
I never actually finished the custom speedo covers, kinda an unfinished project that didn't work as good as I thought. I had trouble getting the speedo needle off to put the cover over, not sure it would work after I was done. Also the cluster light wouldn't shine through the cover that well, it's just laminated prints I had done at kinkos highest quality printer.Meatball wrote:Tyler! Where can I get one of those S3XY Speedometer insert replacements? I was trolling through your photobucket page and almost fell off my chair when I saw them...I NEED!!!! Are they paper? Translucent Plastic? How do they look at night? NEEED ONE!!
