PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
aerorob
Re: PLEASE HELP!!!! [Resurrecting 1987 SE50 Elite -Ed.]
Post by aerorob »
Yeah I wouldn't worry about brakes, my aero pushes 45 and a have stock brakes. Just make sure your shoes are good and your set.
martynkim
Post by martynkim »
Ramp plate came today, Probably start on it today or tomorrow morning. Anything I should know before I tear into this thing? :ndance:
aerorob
Post by aerorob »
so with the vari, getting it off you will need something to hold the outer pulley half in place. or use in impact wrench to rip it off (gently)
just make sure your rollers are in there right, settled in between the vari and ramp plate before you zip the nut back on.
you should get quite a few mphs.
and have you installed the exhaust yet? after you do check your plug to make sure you arent running lean. (you want cardboard brown, no lighter)
let us know how this all goes!
evilone
Post by evilone »
martynkim wrote:Ramp plate came today, Probably start on it today or tomorrow morning. Anything I should know before I tear into this thing? :ndance:
Squeeze the belt down into the clutch as far as you can. You need to have slack in the belt when putting the drive pulley back on (drive pulley has the teeth that the starter engages...opposite the variator). You risk stripping the splines off the crank if you don't have slack, then you'll need a crank.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Post by martynkim »
Ok :*: do you use to get this bolt out?
evilone
Post by evilone »
Can't remember...7mm or 8mm socket. I think 8mm (5/16). Why are you taking that off? You should use the keli variator, ramp, rollers, and slides. Forget about that cover on your old variator unless you're getting to the slides and rollers (new are recommended but use what you got for now if you have to).
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
A thin-walled 1/4" drive 7mm socket or 12-point box-end wrench is required. May need a trip to the Tool Store, Yay!
martynkim
Post by martynkim »
No bolts for the new variator :*: Do I need some graphite or something on the rollers :wink:
aerorob
Post by aerorob »
Leave that brass plate off the vari and throw it away. Also, don't grease the rollers.
martynkim
Post by martynkim »
Here's what i've got.
martynkim
Post by martynkim »
So pitch the backer on the new one??? :hi:
martynkim
Post by martynkim »
OH MY GOD!!! THAT THING HAULS WAY BEYOND ANY SPEED IVE EVER SEEN ON A 50 I HAVE TO SLOW DOWN NOW FOR CORNERS!!! IDK HOW FAST BUT.... I'LL FIND OUT SOON MAYBE I'LL GO GET A GPS!!! :peace: :peace: :peace: :coolcruise: :coolcruise: :coolcruise: :woot: :woot: :woot: :woot: :woot:
evilone
Post by evilone »
martynkim wrote:OH MY GOD!!! THAT THING HAULS WAY BEYOND ANY SPEED IVE EVER SEEN ON A 50 I HAVE TO SLOW DOWN NOW FOR CORNERS!!! IDK HOW FAST BUT.... I'LL FIND OUT SOON MAYBE I'LL GO GET A GPS!!! :peace: :peace: :peace: :coolcruise: :coolcruise: :coolcruise: :woot: :woot: :woot: :woot: :woot:
297 posts later, about d*** time!! :rock:.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Post by martynkim »
It was fun for me :) Thanks to all of you for your help :thumbwink: I couldn't have done it without any of you who advised me 8) Almost sad that it's done. Now to hop up my Spree I think I'm gonna get an Aero motor for it whaddya think Evil? :P
evilone
Post by evilone »
martynkim wrote:It was fun for me :) Thanks to all of you for your help :thumbwink: I couldn't have done it without any of you who advised me 8) Almost sad that it's done. Now to hop up my Spree I think I'm gonna get an Aero motor for it whaddya think Evil? :P
Imagine your 87 elite motor on the lightweight spree frame. That's what to expect with the aero motor (same motor) :woot:
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
