Spree Engine Swap: Honda Elite CH80 onto Spree
Re: Spree Engine Swap: Honda Elite CH80 onto Spree
Post by swimmingfree »
what was the starting whate on that what did you end up with???
deuce217
Post by deuce217 »
Cool, you you have a lathe? Very handy for these scooter projects.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
ped
Post by ped »
Hi tyler.
you always have something interesting going on. :nerd:
I don't thing it makes much of a difference in speed? for the flywheel.
do you think you can give that one a test run? before you cut the other one? :imo:
Tyler VR
Post by Tyler VR »
swimmingfree wrote:what was the starting whate on that what did you end up with???
I have the before weight written down, I weighed it a couple times during the lightening but didn't bother to weigh it after I hit magnet. I have another flywheel on order, I'll get the weights when I try it again.
deuce217 wrote:Cool, you you have a lathe? Very handy for these scooter projects.
I have a friend who owns one, so time it limited and so are my lathe skills. I'm just a hobbyist but have done a few small projects using a lathe in the past.
Tyler VR
Post by Tyler VR »
ped wrote:Hi tyler.
The theory behind lightening flywheels is less rotational mass. It's a popular mod in the ruckus community, most say it helps with acceleration. With a lightened flywheel the engine can rev up easier but also revs down easier which could effect the variator. I might have to offset with heavier roller weights if it messes with my top speed.
I would be too scared try this failed flywheel, it could grenade. :nervous:
Tyler VR
Post by Tyler VR »
I'm trying a clutch mod by putting a shim washer behind the contra spring. I feel a little difference and I like it :D , maybe I'll shim more someday.
patthesoundguy
Post by patthesoundguy »
That washer is a cheap way to get a little more bottom end :-) looks good to me
Tyler VR
Post by Tyler VR »
Finally did another lightened flywheel for the ch80, took this pic while swapping them out. It made my acceleration a little better, seems easier to hit higher rpm. Not a bad mod, I've put about 100 miles on the road with it and planning on leaving it on.
Tyler VR
Post by Tyler VR »
I tried out a spare aero 125 shock, the overall strut length is longer than a ch80 shock but the spring is shorter. It road lower after I put my weight on, it had a softer ride but I didn't really like it so I switched back to the ch80 shock.
Tyler VR
Post by Tyler VR »
I've been looking into carb options for the ch80 again, not much available for the flange size I need. So I'm converting to spigot carb mounting by modding another intake manifold.
Tyler VR
Post by Tyler VR »
Started chopping the flange off, then dremeling it down to size.
Tyler VR
Post by Tyler VR »
paulpauly7
Post by paulpauly7 »
I love you'r "I will take this and make it work " attitude it reminds me of me lol .Great work .
patthesoundguy
Wicked mod. I love it. :-) that's using your noodle ;-)
Tyler VR
Post by Tyler VR »
paulpauly7 wrote:I love you'r "I will take this and make it work " attitude it reminds me of me lol .Great work .
patthesoundguy wrote:Wicked mod. I love it. :-) that's using your noodle ;-)
Where there's a will, there's a way.
