Spree (Nifty 50 here in NZ) - POOR RUNNING!! HELP!
Re: Spree (Nifty 50 here in NZ) - POOR RUNNING!! HELP!
Lunytune wrote:
noiseguy wrote:OK, that "running rough" is called 4-stroking. That's indicative of running rich.
You gotta explain that term for an ole coot who's spent most of his life working on 4 strokers, from lawnmowers to big rigs.
It's one of those things that, once you experience it, you know exactly what it is.
If you take a stock Spree, start it and immediately take off without waiting to warm up and bystarter to kick closed, you'll find that as you reach max velocity the scooter will start shaking and misfiring. It's actually firing every other stroke, or "4-stroking." It will stop once the bike is warmed up.
Bikes running too rich jetting will do this all the time, even warmed up, at accelleration or at a static throttle opening.
"4 Stroking" means the engine only fires "every other" revolution rather than on everytime the piston comes up to TDC. Can be caused by too rich (usually) or too lean (rarely).
