FINALLY FINISHED!! PICS INSIDE!! General Spree
MySpree
Post by MySpree »
hey yea u can. just put them under ur bodypanals. thats what id do im getting one the goes lalalalalala lalalalalala lalalalalalalal lalalalalala lalalalalal lalalalalalalalal olay, la cucaracha haha but for serious i want them doubt ill ge them tho
Justinsane wrote:actually, never mind that.. i found a pic and i definitly wont have room for those bad boys...
What about under the floorpan, or under the sidepanels and above the rear wheel?
Justinsane
Post by Justinsane »
well, im wondering if i can shave part of the horn off, so its just tubes instead of the outword curv of the horn.
i dont think all these will fit... but i will definitly be willing to try if i can get some positive reinforcement and suggestions..[/list]
General Spree
He managed... I'm still thinking under the floor. They also make speaker-driven versions of these (should be smaller), although this would be louder.
Justinsane
i just got an idea., what i think im gonna try is mounting 5 of the horns like this.
id paint them black to go with the asthetic of the General.. but im not sure where id put that module thing?? maybe... i could take out the stock horn, and put it in there?? there might be enough room...
General Spree
tellmem3
Post by tellmem3 »
your right justinsane,
That kicks soooo much *! I was way off thinking you might have put a NOS tank on it. I did dream that however.
I once has a jvc "pullout" car stereo mounted on the rear rack complete with a power antenna and the speaker was under the seat, but since the scooter sat for 15 years outside it rusted to noda. bump bump... Could you make or weld a "small but civilized" box to the rear rack to hold the unit ??
Chris
My other toy is an E30 M3 cause sometimes old school is better
tellmem3
Post by tellmem3 »
Justinsane wrote:well, im wondering if i can shave part of the horn off, so its just tubes instead of the outword curv of the horn.
if you do that your horns will sound like the banshee off that darkness movie.
tellmem3
Post by tellmem3 »
noiseguy wrote:He managed... I'm still thinking under the floor. They also make speaker-driven versions of these (should be smaller), although this would be louder.
Ah nonthing like getting behind a hummer and letting them know your bigger..... Cheers to that
Justinsane
i would like to mount a cd player and box on the back, but im too afraid of theft, so im just gonna listen to my ipod while riding..
General Spree
OK, so mount 2 on each side of the legscreens, painted black and facing downward, and one underneath, facing rearward (dust intrusion). Might be able to use the blinker studs for this. These have PVC tubes running to them from the compressor. You can hide the tubes to the front through the front horn cover and route them under the floorpan along the frame. Attach the horn underneath the frame and plug the hoses into it. The PCV hoses are generic hardware-store stuff, so it's available. You'd need to run a jumper from the front horn to an automotive relay, and probably run a dedicated fused jumper from the Spree battery through the relay to the horn compressor. Thus having the compressor in the back, close to the battery, is ideal anyway.
Not sure of your electrical background, let me know if this makes sense in terms of the relay; it would allow you to use the stock horn swich, and easily reverse the mod. You could mock it up using tape to see how it'll look visually up front.
I have a $10 set of airhorns that I was going to install on a car... might go better on my Spree. I was thinking about installing this on the inside of the legshields. Would be louder out front.
-aL-
neons
Post by -aL- »
do u wanna tell me what you bought on that neon website and how you hooked it up to the moped.. im really interested thnx
darat
Post by darat »
Y is everyone makeing it a big deal about hookin up neon. it is not that hard at all. basic stuff
-aL-
Post by -aL- »
i just would like to know what wires to hook it up to
deathwish
Post by deathwish »
i would hook it straight to the bat and make a switch under the seat
Justinsane
i quickly made this map on how to wire a neon, or neons
General Spree
