Stalling spree
Lunytune
Re: Stalling spree
Post by Lunytune »
banshman wrote:I have created a monster.Why dont I try to clean that hole and Ill let everyone know.I have tommorow off and thats first on my list.
Thanks to everyone for the input.
No, just bringing out the best of Bear. :? And in spite of my abused physics, my scooters run.
Back to basics,
1. Compression. I need a 100 psi inspite of what some say that it will run on 70 psi.
2. Ignition. Good blue flame and clean plug, no tracing.
3. Carburetion. Yes, clean that hole.
Re: Stalling spree
Back to basics,
On the spark thing. Just because at cranking speed you have a blue spark that will jump the plug gap, a mere .025", does not mean the spark is good. When the engine is running, or even trying to start, the cylinder is under pressure and full of air mixed with fuel and oil. Thereby needing a spark the will jump an minimum of 3/8" and preferably 1/2" to 7/16". You need a test to check this. Admittedly the CDI ignition on these scooters are extremely reliable, but there can be a problem. You can make your own tester or just buy a cheapie at Harbor Freight.
http://www.harborfreight.com/cpi/ctaf/d ... umber=4424
or the expensive cheap one
http://www.harborfreight.com/cpi/ctaf/d ... umber=4445
banshman
Re: Stalling spree
Post by banshman »
The verdict is in! I got home and took the carb off again.I sprayed carb cleaner with straw attached through that tiny hole both ways and got flow.I then check the strainer in the tank which was mint.Sure enough it does NOT stall anymore when I stop.I ripped up and down my street and its mint.I cant believe I never did that before.I still would like to know where the factory sets the air/fuel screw since I was messing with it.I know 1.5 to 2 turns out is average but Im still curious.Thanks for everyones input.
Re: Stalling spree
banshman wrote: .........................I cant believe I never did that before.I still would like to know where the factory sets the air/fuel screw since I was messing with it. I know 1.5 to 2 turns out is average but Im still curious.Thanks for everyones input.
The manual says a 1984 -1986 Spree should be 1 1/2 turns out. Just to give you the whole story, the 1987 is 1 3/8 turns.
CharlotteSpreeRider
Re: Stalling spree
Post by CharlotteSpreeRider »
Wheelman-111 wrote:...legendary, un-photographable pilot jet...
To the contrary. For some crazy reason, run of the mill digital cameras are quite sensative to even the slightest contrast. I took the below picture just inside the open garage door here in the middle of a bright sunny day in central Florida. I was holding a flashlight with the bulb pointed up, shining the light up through the upside down carb, so that the light shined up through the hole where the throttle cable goes into. My thumb was covering the port where the main jet and emulsion tube normally live. Just to the right of my thumb you can see the light through the pilot jet. It looks like it is dancing because I couldn't hold my right hand still enough while trying to photograph this. This carb has not had anything stuffed into it or cleaned at all, this was how it looked straight off this running bike. To be clear, you cannot see the light through the pilot this easily with the naked eye. The camera picks up the contrast and makes it much more obvious.
Spree idle jet
Spree idle jet
-CharlotteSpreeRider
Re: Stalling spree
Good idea and nice photo CharlotteSpreeRider. I have shined lights into the carb looking for that elusive light, and torn apart a carb to find the passage is offset from the pilot jet. Your photo 'shines' :thumbwink:
Lunytune
Re: Stalling spree
Post by Lunytune »
CharlotteSpreeRider wrote:
Wheelman-111 wrote:Just to the right of my thumb you can see the light through the pilot jet.
HE SAW THE LIGHT. Wheelz is not crazy, you can see the light.
Well, at least Rider notes that it can't be seen with the naked eye. Nonetheless, he got the photo to prove it and I am now a believer. Guy, I'm sorry I maligned you. :nerd:
Dirty Stinkin' Liars
Hey now!! Whaddya mean I'm not crazy?! You're talking about a dude who coulda cured cancer or acne or World Hunger or somethin' had I devoted the same amount of time to activities more constructive than rehabilitating a couple of obsolete 50cc scooters. If that ain't crazy, what is? Anybody got any Haldol? My cat's sprouting wings again... :crazy:
Lunytune
Re: Stalling spree
Post by Lunytune »
Wheelz, I had to ask my wife about that Haldol. She's a psych nurse, and stays busy trying to keep me from falling off the high wire. :coolcruise:
Re: Stalling spree
Then you come by your Forum handle honestly. Get her somethin' nice. She has a tough job.
