Request for input - Parts Spree 84/85 vs 86/87 and SB50
martynkim
Re: Request for input - Parts Spree 84/85 vs 86/87 and SB50
Post by martynkim »
Wheelman-111 wrote:Greetings:
From reading here, the carb numbers vary by year but they interchange freely. The Spree carb is quite different from the Aero/Elite carb physically. The bystarter is on the opposite side of the venturi, so an Aero carb can foul the shock. Even though they might fit. I suspect the Spree carbs won't work on the Elite/Aero engines due to a very small pilot orifice - cast-in to the body.
Thanks for the answer as I am looking at the interchange of an 85 to an 87 Spree. The parts fiche from my local Honda shop shows different P/N's. I understand the differences in the variated AF motor and the non varied Spree carbs.
b18Eric
Post by b18Eric »
The flywheel from an 84 will work with the alternator coil from an 86 so no need to swap the coils/flywheel as a pair! Got pics if needed.
Bossshelby
Post by Bossshelby »
The spree has two different gears. the earlier is 12 tooth and the later has 13 tooth but the big gears stayed at 82 tooth for all years. The 12 tooth has a limited speed of 25mph.
Have 4, 84-86 Sprees
Sprite-85 Honda spree
-87 elite 50 engine
-90 jet
-9 and 10 gram rollers
-Highly ported intake and exhaust
-custom performance muffler
3 original sprees. A red, black and white
jakewright
Post by jakewright »
Will 86 nq50 transmission drive gears fit in my 85 nq50 transmission case?
eclark5483
Post by eclark5483 »
84/85 kickstand is shorter then 86/87 kickstand.
chewy812
Post by chewy812 »
86 Honda spree Nq50
Will a 87 carburetor work on a 86 Honda spree ?
eclark5483
yes
chewy812
Post by chewy812 »
Need some help on this 86 Honda spree I put a carburetor in from a 87 Honda spree. Now I can’t keep it running I adjust the air mixture screw and nothing happens. And when I give it full throatle it dies. Any idea
I replaced the carburetor cause I put the long screw in where the short one goes will that cause a problem ?
Search for air leaks.
Make sure the airbox is tightly sealed.
Wirie01
Post by Wirie01 »
Hi does anyone know if the rear tire of a 87 aero will fit on a 90 dio?
harleyracer59
Post by harleyracer59 »
yes. they both are 95mm drum brakes and shaft and spline count are the same on early dios. I think I read here at a certain year the changed the shaft diameter. I don't remember what year though. I believe variated af05 axle shafts are the same a 93-98? dio. I don't remember if its 98 or later. I have test tried an aero on both 93, & 94 af16 ive had and an af18 (year unknown). fit all of these fine
Wirie01 wrote: Thu Apr 09, 2020 7:58 pm Hi does anyone know if the rear tire of a 87 aero will fit on a 90 dio?
I wonder if this poster means the WHEEL when he says TIRE ?
These kinds of questions need some further explanation.
The poster may never return, too, as it is #1 post.
:hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :hi: :coolcruise:
harleyracer59
good eye mike, I didn't even pick up on the tire part. lol
hope youre good and staying healthy! take care
otto-man
Post by otto-man »
While reviewing this site, I came upon the part about crankshaft bearings that anyone rebuilding a 1986/1987 Honda Spree should be aware of. The drive side bearing stated to be a generic 6204 (20x47x14) is too wide. I tried one a few years ago and the cases will NOT come together. The correct bearing is a 20x47x12. There may be crankcases out there that will accept the wider bearing, but I haven't found one yet. Just be sure that when you remove the old bearing, you measure the width. That will save you a HUGE headache. Good luck.
otto-man wrote: Thu Feb 18, 2021 3:56 pm While reviewing this site, I came upon the part about crankshaft bearings that anyone rebuilding a 1986/1987 Honda Spree should be aware of. The drive side bearing stated to be a generic 6204 (20x47x14) is too wide. I tried one a few years ago and the cases will NOT come together. The correct bearing is a 20x47x12. There may be crankcases out there that will accept the wider bearing, but I haven't found one yet. Just be sure that when you remove the old bearing, you measure the width. That will save you a HUGE headache. Good luck.
I have edited this item in the original post along with the other Edits. Good watching out otto-man :thumbwink:
