right now i have a 45 and 122. I couldn't get the 50 you suggested yet... but anyway, the engine is kind of groggy from start, at least that i use the throttle gently on the first 1/8 of a turn or somewhere around that.
I will disconnect the little hose from the top today... but i need to get another with a loop pointing down so i do not leave it exposed to the rain. My scooter gets wet every day sitting under the rain.
Thanks
Honda dio cdi derestriction
Re: Honda dio cdi derestriction
1989 Honda Dio SP
AF18E - 82cc Taiwan kit - 24mm Oko - KRS pulley kit - Kevlar belt - 8.44:1 gears - 1000RPM Center spring - 7 grams roller weights - R1 sectional exhaust - 130lb pilot
