You don't need one. The pump is driven outside of the crank case. Just pull it and cover the hole with some scrap whatever to keep debris out.Trafficjamz wrote:Are there oil pump plugs for the 1996 jog?eliteguy50 wrote:When you get to that level of performance, you should also remove the oil pump.bakaracer wrote:there are aftermarket rotor kits. this replaces the stock heavy mag and stator. the aftermarket ones are aluminum and weight about half the weight of the stock mag/flywheel. the ncy ones sell for about $250. the malossi ones are about $450. all the guys in europe that race minarelli motor bikes use rotor kits on their bikes. makes it rev up quicker and frees up rotational mass weight off the crank.so that means more hp too.every little counts in these small engines.
http://www.scooterpartsplace.com/ncy-al ... og-50.aspx
Where could I find one?
Just got a 1996 yamaha jog
Re: Just got a 1996 yamaha jog
