Page 3 of 5
Re: this is what happened
Posted: Sun Oct 24, 2010 3:19 pm
by nitroelite419
Posted: Sun Oct 24, 2010 3:41 pm
Tj knows more about the jetting of this carb than I do, listen to him.
Posted: Sun Oct 24, 2010 4:41 pm
by evilone
nitroelite419 wrote:so is a 130 main and a 45 slow what you recommend also? Like tj said
I recommend a 138 main and a 55 pilot.
Posted: Sun Oct 24, 2010 5:10 pm
by Trafficjamz
Evilone has been tuning these carbs longer than me.
His suggestion is probably a safer combo than what i suggested.
I would buy a bunch of different jets. Elevation and temp have a lot to do with what jets you will need.
Also disable the power jet if your carb has one. (the pink tube that leads into the mouth of the carb)
I stuff little ball bearings in the tube to disable it.
The main jet is super easy to replace in an OKO carb. Tools required are a 17mm socket and a 1/4" nut driver.
The too small main jet in you carb now is your problem for sure.
Posted: Sun Oct 24, 2010 6:23 pm
by evilone
Trafficjamz wrote:I would buy a bunch of different jets. Elevation and temp have a lot to do with what jets you will need.
My jet recommendation is based on a similar setup and my location. get a bunch of different jets like Tj said.
Posted: Fri Oct 29, 2010 1:57 pm
by nitroelite419
ok got my jet kits installed a 140 main and a 50 pilot, my idels good, but now its dripping oil out of the exhaust and theres a lot of gas comin out the carb???????
Posted: Fri Oct 29, 2010 2:22 pm
nitroelite419 wrote:..................................theres a lot of gas comin out the carb???????
Where is the gas coming out of the carb?
Posted: Fri Oct 29, 2010 2:38 pm
by nitroelite419
out of the overflow and between the carb and bowl theres alot
Posted: Fri Oct 29, 2010 2:45 pm
Then your float is either bad or you have trash in the needle and seat. Do you have new fuel lines and an additional in-line fuel filter? If not change the lines and add the filter.
Posted: Fri Oct 29, 2010 9:53 pm
by Trafficjamz
Bear45-70 wrote:you have trash in the needle and seat.
Take the carb bowl off and clean it out. You might have got some dirt or something down in there.
Posted: Sat Oct 30, 2010 9:18 am
by StrokedSr
the jets that are stock in that carb are 130main and 39 pilot...
Posted: Sat Oct 30, 2010 9:57 am
by nitroelite419
i guess the Keihin carb i hace is a copy carb, Its like 3 differt carbs built into one, Im going to try to mix up another batch of gas, Its still really smoky and boggy
Posted: Sat Oct 30, 2010 12:31 pm
by Trafficjamz
Did you get the gas to stop leaking out of the carb?
Posted: Sat Oct 30, 2010 1:10 pm
by nitroelite419
im going to install the other fuel filter and see what happens, I hope thats the problem, I took the bowl off, its clean. The float wasnt sticking, so i dont know. Ill just have to try the filter..
Posted: Sat Oct 30, 2010 1:22 pm
by nitroelite419
so the bigger the number on the pilot jets means what
