For the few who decided for whatever reason to stick with the stock carb on a big-bore application, I offer the following:
Stock airbox can be a challenge to adapt. The bike can work, but it's hard to get it to run well, even harder to exploit the full potential of the 72+ cc bore kits.
The UNI open pod filter works fairly well but is loud. My Arreche "Octopus" is a little more muffled:
Lurking inside is a home-made "adaptor" consisting of a 2" length of clear Polyurethane hose, whose wall thickness adds enough to the 28mm carb bellmouth to match the Arreche's 35mm donut. The length of the hose can be "tuned"; an ongoing experiment.
JETTING: The
109 ran well - a few burbles and episodes of 4-stroking - but I felt it was still too warm, especially in the humid Deepinnaharta mornings. A calculated gamble to drill it out to a #56 Indexing drill - measured out to a 112 diameter -
FAILED! It started and did OK until the throttle was opened. Thereupon it burbled and smoked and had little-to-no power. It didn't run long enough to allow the bystarter to close, but regardless, I had to get to work. I didn't have time this morning to lower the needle a clip or two, which I may try before swapping jets again.
Sounds like the ideal jet is around a 110 with my current setup, doesn't it?
Here's Flash Scootertrash III as of today:
