86 spree just bought runs like crapp..nedd help!!!!
spewya
Re: 86 spree just bought runs like crapp..nedd help!!!!
Post by spewya »
are you talking about me .. ok i dont need that ... IÔÇÖm sorry if i dont easily comprehend some of things that you know all about... i dont get much time on the computer so when i do im always rushing .. dont you think instead of saying that i suck at reading, you could post something more productive so i understand better, to benefit me with my spree problem and know exactly what im doing before i go ahead and look for the problem when i dont know what im looking for? Not how i read and ask questions... what are you hear for... to help people out or criticize how i read and comprehend? Come on man i really didnt need that... IÔÇÖve learned a lot so far and being that IÔÇÖm only 15, IÔÇÖm pretty proud at how much IÔÇÖve accomplished, but at the same time, a lot of it has come from being on this forum and i thank you all for the knowledge you share. What people say here is technical enough for me to understand and not annoy all of you with too many questions ...but nobody likes to be put down.
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
spewya wrote:are you talking about me .. ok i dont need that ... IÔÇÖm sorry if i dont easily comprehend some of things that you know all about... i dont get much time on the computer so when i do im always rushing .. dont you think instead of saying that i suck at reading, you could post something more productive so i understand better, to benefit me with my spree problem and know exactly what im doing before i go ahead and look for the problem when i dont know what im looking for? Not how i read and ask questions... what are you hear for... to help people out or criticize how i read and comprehend? Come on man i really didnt need that... IÔÇÖve learned a lot so far and being that IÔÇÖm only 15, IÔÇÖm pretty proud at how much IÔÇÖve accomplished, but at the same time, a lot of it has come from being on this forum and i thank you all for the knowledge you share. What people say here is technical enough for me to understand and not annoy all of you with too many questions ...but nobody likes to be put down.
So to your way of thinking I should just answer your question again. Ahhh, Nope that is not gonna happen. I was 15 once and if I didn't pay attention I heard about just like you did. So suck it up, shut up and learn from your mistakes. :roll:
spewya
Post by spewya »
what exactly is my mistake . i didnt say i want you to do every thing for me. i just like all the advice and help and all i was doin was telling you i dont need to be put down .so will you not make this an aguement and continue to help me like i said i cant get much time on the computer so i have no time to read up on my problem .its just easy to ask and get my question answered asap by some one that knows
spewya wrote:what exactly is my mistake . i didnt say i want you to do every thing for me. i just like all the advice and help and all i was doin was telling you i dont need to be put down .so will you not make this an aguement and continue to help me like i said i cant get much time on the computer so i have no time to read up on my problem .its just easy to ask and get my question answered asap by some one that knows
According to your own words you have a limited amount of time on the computer, yet you waste time not reading others answers to your questions and then waste more time asking the question again. You logic is badly flawed also. You waste more time whining about being wrong and blaming others because you can't admit you are wrong. And after this little exercise I now am sure you screwed up the carb assembly and that is why you have a problem, but of course you will not admit that either. I'm done, one can't teach those who refuse to learn from their own mistake or from others.
spewya wrote:its just easy to ask and get my question answered asap by some one that knows
Yes, it's easy to ask. But you're not listening. That is the problem.
I'm still convinced that your slide's in backwards. In fact, more so.
Come back to us later with some pictures of your carb. Try to get a good one looking into the carb from the air cleaner. Those will be worth 100 of these posts.
KillinSpree
Post by KillinSpree »
Its either your slide is in backwards, you have a junk gasket where your intake buts up against your engine block, or the plastic gasket between your intake and carb could be on wrong or the rubber seal in that gasket could be riped or missing (resulting in vacumm leaks which causes high idle). If worse comes to worse download or print out the whole service manual off this site and it should answer all your questions!
1984 Honda Spree White
1987 Honda Spree Blue
spewya
Post by spewya »
can the gasket inbetween the carb and intake be put in backwards or flipped
KillinSpree wrote:Its either your slide is in backwards, you have a junk gasket where your intake buts up against your engine block, or the plastic gasket between your intake and carb could be on wrong or the rubber seal in that gasket could be riped or missing (resulting in vacumm leaks which causes high idle). If worse comes to worse download or print out the whole service manual off this site and it should answer all your questions!
Yes, The o-ring on the spacer goes against the manifold, the carb o=ring seals to the spacer. You can also install thr insulator (spacer) upside down and yes it can cause a vacuum leak.
KillinSpree
Yea. If you look at your intake hole and put the gasket up against it you will know what way it goes because if its not correct the holes on the intake and gasket will not line up.
There's a little arrow on the thermal decoupler (otherwise known as the brown plastic thing) that you should be able to see and should point forward if the thing is installed correctly.
There are 3 ways to install it wrong of a total of 4... something like 1/2 the bikes I work on have it installed wrong.
Correct installation of the carb insulator is easy, 2-step process:
1. "Dog Ears": Downward.
2. Don't duplicate the o-rings.
spewya
Post by spewya »
ok that sounds good .. ill check in to that.. how would i go about posting pictures on this site??
When you "Reply" or start a new topic, the field below the text area has a "Filename - Browse" button. If your pics are on your computer, you can find them and "Add the file" to your post. You can "Place Inline" if you want the pic to appear within the text part of your post.
spewya
Post by spewya »
could my problem also be the reeds??
devenex
Post by devenex »
If there was something wrong with the reeds you would have trouble keeping the engine running at low rpms. It would not be idling too high as you described.
1986 Spree w/ '87 SE50 motor
