Page 3 of 4
Re: Ch-ch-ch-- no engine movement when trying to start
Posted: Thu Mar 10, 2011 12:37 pm
by jrmints
Bear45-70 wrote:That's called compression, a requirement for the engine to run.
Okay, so that's a good thing (?)
Once it hits that point, the engine struggles to keep the fan turning and sometimes it can't.
Posted: Thu Mar 10, 2011 12:45 pm
Without it the engine can not run. To make an engine run you need 3 things;
1) Compression, in these engines case about 80 to 90 PSI to run and 115 PSI to meet the manufacturer's spec.
2) Fuel, a a sufficient fuel to air ratio to have combustion, 14 to 1 is ideal.
3) Spark, enough spark to ignite the mixture at the right time.
FYI Jr Mints have always been one of my favorite candies.
Posted: Thu Mar 10, 2011 12:53 pm
by jrmints
Always been my favorite screen name :)
Checking those three things now.
e: I'm reading Fred's Guide, and I don't think I'm getting enough compression. I did the whole thumb-plugging-spark-hole thing and while it did give off some pressure, it wasn't nearly enough to pop my thumb off.
Posted: Thu Mar 10, 2011 1:05 pm
jrmints wrote:
Bear45-70 wrote:
jrmints wrote:Okay, so that's a good thing (?)
The thumb method tells you nothing. Get a compression gauge and really check compression properly. * 40 PSI will pop your finger off the plug hole, but the engine will NEVER run with 40 PSI compression.
Harbor Freight has gauges on the cheap.
http://www.harborfreight.com/flex-drive ... 92697.html
Posted: Thu Mar 10, 2011 1:43 pm
by jrmints
Okay, you guys are going to hate me (moreso if you already do), but I decided to take the cylinder head off to check the piston. The top is covered in carbon. I'm cleaning it now. Does any kind of oil/lubricant belong on it when I put it back together with the metal accordion thing that the muffler attaches to?
Posted: Thu Mar 10, 2011 1:47 pm
jrmints wrote:Okay, you guys are going to hate me (moreso if you already do), but I decided to take the cylinder head off to check the piston. The top is covered in carbon. I'm cleaning it now. Does any kind of oil/lubricant belong on it when I put it back together with the metal accordion thing that the muffler attaches to?
Cleaning the piston top and the head will LOWER your compression. It is hurting nothing at this point and cleaning is a waste of time. Put a very small amount of 2 stroke oil in the cylinder before you reinstall the head, maybe a 1/4 of a teaspoon. You are aware you need a new head gasket now, are you not?
Posted: Thu Mar 10, 2011 1:49 pm
by jrmints
Aware now. I think I read that low compression can be caused by blown gaskets, so it probably wouldn't hurt, n'est-ce pas?
e: is the gasket supposed to be fused to the engine?
Posted: Thu Mar 10, 2011 2:20 pm
by eliteguy50
jrmints wrote:New development: I've noticed that when I try to spin the fan manually, or kickstart, there's a spot where it starts being hard to spin. Once you push past that spot, it'll spin fine until you hit it again.
Compression build up is good as Bear said, as long as it is smooth when you turn it.
Posted: Thu Mar 10, 2011 2:55 pm
by jrmints
More fun discovery, those two rings around the piston are both broken.
Posted: Thu Mar 10, 2011 3:08 pm
by eliteguy50
jrmints wrote:More fun discovery, those two rings around the piston are both broken.
The e-start sounded fast to me.
Yes, the cylinder base gasket can be a pain to remove. It is best to clean the dirt off of the block before removing the head. That way everything is enclosed so you wont get dirt it the bottom end. Broken rings could mean a new bottom end if the pieces found their way into the crank bearings.
Posted: Thu Mar 10, 2011 6:25 pm
by jrmints
....am I crazy for wanting to put a big bore kit on it now?
I mean, maybe it'll be usable in the city if a 48mm can haul a 160-lb chick around...
dammit, this forum is getting to my head!
Posted: Thu Mar 10, 2011 6:27 pm
jrmints wrote:....am I crazy for wanting to put a big bore kit on it now?
No, It will be as cheap as replacing with OEM parts.
Posted: Thu Mar 10, 2011 8:16 pm
Rings are "broken"? Sorry if this sounds elementary, but rings have a split to permit installation and expansion.
I would expect a broken ring to fall off the piston in at least 2 chumks upon withdrawal from the cylinder.
Posted: Thu Mar 10, 2011 9:22 pm
by eliteguy50
Wheelman-111 wrote:Greetings:
I was wondering about that but I can't open the attached picture. :( Is there a secret method that I am not using?
Posted: Thu Mar 10, 2011 10:39 pm
by jrmints
No, no, I mean split into several pieces. I fished all of them out, though. They were stuck onto the piston with some kind of... goo.
