Page 3 of 4
Posted: Sat Feb 25, 2006 1:17 am
by darat
i got the high speed pulley kit a 87 main jet , shoot shiney coil, i have a 36 pack of roller weights so i can go from 3 to 14 grams.. and as for the clutch i have a 1000 rpm center spring and thats about it..
Posted: Sat Feb 25, 2006 1:42 am
by MySpree
and i still win races against u... and im stock!
Posted: Sat Feb 25, 2006 4:09 am
by 85stroka
does the pulley kit have a ramp? if not get the sef or the daytona if you want to spend some bucks!
try change your clutch springs so you build more rev,try a higher center spring say 1200,1500, I not sure if you can run a 2000, I would call VT and see,I really dont know much ,and that your bike is still a stock cc's I know even less.
You want your bike to rev - pull all the way up top-if it flatens out near the topend drop the weights, I have no idea what your running but I run 45 grams for my stroker !
Posted: Sat Feb 25, 2006 4:32 am
by bitteraspects
not daytona. SEF all the way
Posted: Sat Feb 25, 2006 12:08 pm
by hrnytrtlsgsxr
MySpree wrote:and i still win races against u... and im stock!
are you guys the same weight?
the 1500 spring might work with the stock assembly but yeah check with VT with what spring set up you could go to on a stock aero. yet the pulley ramp will halp a little.
Posted: Sat Feb 25, 2006 12:33 pm
by darat
mine is not the areo..
Posted: Sat Feb 25, 2006 12:41 pm
by MySpree
uhhhhhhhhhhhhhhhhhhhhhhhh man i forgot what i was gonna say...
Posted: Sat Feb 25, 2006 2:05 pm
by MySpree
o yea. what spring do you think would be good for a honda aero with a variator kit. and a shoot shiny coil?
Posted: Sat Feb 25, 2006 3:57 pm
by 85stroka
1000?i thing 1200 will be aittle high,change the clutch springs too
Posted: Sat Feb 25, 2006 3:58 pm
by MySpree
would a 1500 do?
Posted: Mon Feb 27, 2006 1:44 pm
by 85stroka
I am not sure if you can actually go that high,
Posted: Mon Feb 27, 2006 9:24 pm
by MySpree
well that, with aa speed variator and a shootshiny adn a ligth weight fan... think its too high?
Posted: Mon Feb 27, 2006 9:28 pm
by 85stroka
DONT GET THE FANS, the stock ones are the best you can run!
unless your coil is crapping out dont get that either,
Posted: Mon Feb 27, 2006 10:05 pm
by MySpree
uhhhhhhhh qwll my coil is screwed...
Posted: Tue Feb 28, 2006 1:27 am
by 85stroka
MySpree wrote:uhhhhhhhh qwll my coil is screwed...
