Page 3 of 5
Re: 40 MPH Spree
Posted: Sun Apr 03, 2011 1:48 pm
by Petrock's 1984 Spree
Mine has the exact same thing and its a 1984 Iowa Spree
EDIT- just looked at the vin and it is a jh2. So maybe all japan spree's have this?
Re: 40 MPH Spree
Posted: Sun Apr 03, 2011 1:54 pm
by mopeds4sale
Bear45-70 wrote:mopeds4sale wrote:Most sprees will not even run without the airbox.
If yours did 40 without it, it would be the first time in spree history.
Not always true Tjamz I have had several honda sprees that would run like a raped ape with no air box. And yes I have had one up to 38(flat ground) with no air box and GPS verified. Most will run with out the air box you just have to turn in the air/fuel ratio screw in all the way. I do not suggest doing this but when you buy a spree for $20 and can ride it like that for a summer it is well worth the risk.
This is pure BS. The fuel/air screw only effects idle to at most 1/4 throttle. It's effect at WOT is at best 1 to 2% of the fuel being used. What is this a Liar's Moon? Fantasies will not work here.[/quote]
I did not say I got my top speed from the fuel/air screw being in. I said thats what you need to do to make them run and idle with no air box.
Re: 40 MPH Spree
Posted: Sun Apr 03, 2011 1:56 pm
by SpreeMadness520
mopeds4sale wrote:Bear45-70 wrote:mopeds4sale wrote:Most sprees will not even run without the airbox.
I did not say I got my top speed from the fuel/air screw being in. I said thats what you need to do to make them run and idle with no air box.[/quote]
Re: 40 MPH Spree
Posted: Sun Apr 03, 2011 10:25 pm
by boostedbuick
84 model year sprees read 10 20 30 40, according to the sticky in the tech section. My 84 also has this speedometer. Mine's an early build 84, like number 5000 or so (according to vin).
Re: 40 MPH Spree
Posted: Mon Apr 04, 2011 1:00 am
Mopeds4Sale asserted:
I disagree, Dawg. The air bleed affects more than I might have thought. Axt Baka-san, who done taught me and many others a few things.
Re: 40 MPH Spree
Posted: Mon Apr 04, 2011 1:32 am
by Spreetard
I dug out this old pic today.
That's around 42.6. Give or take. Even gps's can vary by a few mph from model to model.
The bike had the stock airbox in tact, stock jet in the carb. The airbox is not a weak point and is best left alone. FLOW BABY FLOW!!!! And lots of pully mod.
Re: 40 MPH Spree
Posted: Mon Apr 04, 2011 1:43 am
Wheelman-111 wrote:Greetings:
Then why is this chart pretty much accepted by the industry. Remember we are talking a PA series carb, not a PB or an OKO style. Entirely different animals because of the changeable pilot jet.
Re: 40 MPH Spree
Posted: Mon Apr 04, 2011 7:29 am
by woodman
i really do like it when a debate fires off i end up learning alot lol thanks!
Re: 40 MPH Spree
Posted: Mon Apr 04, 2011 8:23 am
by mopeds4sale
That was not my quote that was the bear.
Re: 40 MPH Spree
Posted: Mon Apr 04, 2011 8:25 am
by mopeds4sale
Bear vs the Wheelman it is going to be epic.
Re: 40 MPH Spree
Posted: Mon Apr 04, 2011 9:38 am
Sorry for the mis-assigned quote, 4.
The chart The Bear posted has value to help us understand which carb feature does what. I'm pretty sure it's a Mikuni publication. I'm also pretty sure one can't apply
all of its assertions to any other carburetor.
Of this I am certain. On Bakaracer's advice, I've begun "Pre-tuning" my OKO 26's air screw before mounting up. It's within a very narrow range; 1.5 turns out for cooler mornings and 1.75 for the warmer afternoon ride home. Besides the palpable improvement in mid-throttle response, I've noticed that when I fail to turn it in that quarter-turn, my temps are about 25 degrees higher in the morning than when I do. (Admittedly the VDO gauge isn't the most accurate or easy-to-read instrument in the world...)
What I think is happening is that the air bleed regulates the idle mixture as suggested in the graph. I think it's also letting a trickle of air combine with the fuel in the Emulsion Tube tower, so the "fuel" joining the main flow in the venturi has a bit more air bubbles in it too. I'll be the first to admit I haven't examined the OKO carb's circuit schematics very closely. Also, what happens on the OKO may not be true for the PA.
As a side note, KyleBo sent me his
process and pics for modding the Pilot circuit, posted in Advanced Tech. Worth a look to anyone trying to BBK or Intake Mod a Spree/SB or any stock-carb scooter.
Re: 40 MPH Spree
Posted: Mon Apr 04, 2011 10:23 am
by bradthreee
Whats with the pre-tuning? Link for that?
Re: 40 MPH Spree
Posted: Mon Apr 04, 2011 11:46 am
The trouble with posting this link is that, yeah he modified the carb BUT he has not tried it. I don't thing it will work for one major reason. The OKO and the PB series carb do not have two fuel circuits like the PA series carb does. But they have THREE fuel circuits. The idle and main circuits like the PA series but they also have an intermediate circuit which is the pilot jet. I think the idle will be way to rich to work and all the adjusting in the world will not lean it out to the point where it will work at idle.
Re: 40 MPH Spree
Posted: Mon Apr 04, 2011 12:33 pm
Brad, here's the "Link":
Bear you're right, we're posting uncharted and untested mods as fact. However that's mentioned in the post, and anyone attempting to duplicate or refine the process is thereby notified.
Re: 40 MPH Spree
Posted: Tue Apr 05, 2011 9:45 pm
by Milkyway49
I have also seen with my to eyes my spree do 39mph.
