72cc looking to run 9.1 gears
fastplastic
Re: 72cc looking to run 9.1 gears
Post by fastplastic »
just get a really nice pipe for it makes a world of difference :thumbwink:
scottinscotty
Post by scottinscotty »
i've got a tecnigas next r pipe coming for mine.. will see if that helps out, i might also fab up an intake for my stock carb... hopefully have my pipe in a couple days :ndance:
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
scottinscotty
spi scootershop has em' for 105 shipped!
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
scottinscotty
just a heads up.. with my polini contesta, oko variator, jetted carb, uni .. my setup hit 60 and ran out of space... my boy has a built aprilia with a speedo that goes upwards of 60 and he matched me... so it's gotta be pretty accurate... by the way it's still the stock carb.. and about 7900 rpm..
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
metric
Post by metric »
If you could still get the Leo Vince pipes you wouldn't have any problems 65 I still got one and wont sell it for the world
Post by eliteguy50 »
metric wrote:If you could still get the Leo Vince pipes you wouldn't have any problems 65 I still got one and wont sell it for the world
Which model from Leo Vince?
HI808SYM
Post by HI808SYM »
scottinscotty wrote:just a heads up.. with my polini contesta, oko variator, jetted carb, uni .. my setup hit 60 and ran out of space... my boy has a built aprilia with a speedo that goes upwards of 60 and he matched me... so it's gotta be pretty accurate... by the way it's still the stock carb.. and about 7900 rpm..
you still running the stock exhaust and hitting 60+ with stock carb? AF16?
I've owned stock, 9:1, 8.4:1, 7.97 and currently 7.5:1 gears. The ONLY time the ratios make a difference is in the 0-8MPH range. After that, the variator takes over and er... Variates. I found lightening up the weights a few grams compensates for the higher "hard" gearing in the tranny case by running the belt in a lower "gear. Hills absolutely are not a problem unless you come to a dead stop and have to re-accelerate. Another trick is to convert to a ZX transmission - the rear pulley, belt and boss - so your "low" variator gear becomes lower. But that's just me...
HI808SYM
Post by HI808SYM »
thanks wheelman. i have a sym dd50 so i think it already has the ZX seup.
fastplastic
[quote="Wheelman-111"]Greetings:
I found lightening up the weights a few grams compensates for the higher "hard" gears quote]
i got a 2.7 sec 60 ft time with 8.4's which was thanks to some 6 weights :geekdance:
