Page 3 of 3
Re: 72cc looking to run 9.1 gears
Posted: Sat May 07, 2011 9:23 pm
by fastplastic
just get a really nice pipe for it makes a world of difference
Posted: Sun May 08, 2011 10:10 pm
by scottinscotty
i've got a tecnigas next r pipe coming for mine.. will see if that helps out, i might also fab up an intake for my stock carb... hopefully have my pipe in a couple days
Posted: Sun May 08, 2011 10:11 pm
by scottinscotty
spi scootershop has em' for 105 shipped!
Posted: Tue May 10, 2011 10:13 pm
by scottinscotty
just a heads up.. with my polini contesta, oko variator, jetted carb, uni .. my setup hit 60 and ran out of space... my boy has a built aprilia with a speedo that goes upwards of 60 and he matched me... so it's gotta be pretty accurate... by the way it's still the stock carb.. and about 7900 rpm..
Posted: Tue May 10, 2011 11:21 pm
by metric
If you could still get the Leo Vince pipes you wouldn't have any problems 65 I still got one and wont sell it for the world
Posted: Wed May 11, 2011 5:01 am
by eliteguy50
metric wrote:If you could still get the Leo Vince pipes you wouldn't have any problems 65 I still got one and wont sell it for the world
Which model from Leo Vince?
Posted: Tue Aug 02, 2011 5:13 pm
by HI808SYM
scottinscotty wrote:just a heads up.. with my polini contesta, oko variator, jetted carb, uni .. my setup hit 60 and ran out of space... my boy has a built aprilia with a speedo that goes upwards of 60 and he matched me... so it's gotta be pretty accurate... by the way it's still the stock carb.. and about 7900 rpm..
you still running the stock exhaust and hitting 60+ with stock carb? AF16?
Posted: Tue Aug 02, 2011 6:05 pm
I've owned stock, 9:1, 8.4:1, 7.97 and currently 7.5:1 gears. The ONLY time the ratios make a difference is in the 0-8MPH range. After that, the variator takes over and er... Variates. I found lightening up the weights a few grams compensates for the higher "hard" gearing in the tranny case by running the belt in a lower "gear. Hills absolutely are not a problem unless you come to a dead stop and have to re-accelerate. Another trick is to convert to a ZX transmission - the rear pulley, belt and boss - so your "low" variator gear becomes lower. But that's just me...
Posted: Thu Aug 04, 2011 3:41 am
by HI808SYM
thanks wheelman. i have a sym dd50 so i think it already has the ZX seup.
Posted: Thu Aug 04, 2011 1:26 pm
by fastplastic
[quote="Wheelman-111"]Greetings:
I found lightening up the weights a few grams compensates for the higher "hard" gears quote]
i got a 2.7 sec 60 ft time with 8.4's which was thanks to some 6 weights
