Local Vespa shop installed my 65cc bore kit on 87 elite se50
- 85spreeelite
- 85spreeelite
- 85spreeelite
- 85spreeelite
- 85spreeelite
Check list
Compression--------------------------------Check
Spark----------------------------------------Check
Arrow on piston pointing to exhaust port-Check
New polini carb installed-------------------Check
Reeds intect---------------------------------Check
New petcock---------------------------------Check
New spark plug-----------------------------Check
But still nothing other then a Putt.........................Putt
Jay? Do you have any suggestions?
Is that the list that you and Matt went through?
- 85spreeelite
- hrnytrtlsgsxr
usually if the bike can run run but seems off.Check the plug. If the plug is like a wet black. The cdi could be bad. Although it is giving off a spark the timing is off hence the wet black fouled look on the plug.85spreeelite wrote:No thats the list I checked myself jay. CDI? How do I check if its bad stroka?
stankyoleman
