Sym dd w/ hona dio engine i need help please!
jacob789
Re: Sym dd w/ hona dio engine i need help please!
Post by jacob789 »
i know thanks tho. what does it mean when people say there gears are tall?
808BMW
Post by 808BMW »
tall/long gears = high speed
jacob789
Post by jacob789 »
eliteguy50 how long did scooter assassins take to deliver to you?
Mystic
Post by Mystic »
it will take about 10 days
jacob789
Post by jacob789 »
but i ordered it on 15/08/11 and then it was dispatched on 23/08/11, do you mean 10 days from when it was dispatched?
jacob789
Post by jacob789 »
ok just got a new drive belt fitted and its given me some more top end (not sure how much yet but i will find out tomorrow), the old one was really worn so that was holding me back, my gear-up kit arrived today so i might be able to get that fitted tomorrow then i will see what my top speed is. Does anyone know if the 35mm air filters on scooter assassins fit the OKO 21mm flat-side carburetors because on the description for the carb it says 'These use any 48mm power air filter' but it doesnt mention 35mm ones, anyone know?
thanks
The OKO carbs from 21 to 30 have a 50mm bellmouth. Not sure what a 35 will fit, but it won't fit the OKOs.
jacob789
Post by jacob789 »
ok thanks but the 48mm air filters fit dont they? it says they do?
jacob789
Post by jacob789 »
The Intake, Carb, and Filter all look compatible with each other. Only thing I haven't personally verified is the fit of the OKO CT intake on the Sym cases, but that can be presumed from Forum input - the case ports should be the same as the AF-16 and later bikes.
jacob789
Post by jacob789 »
ok thanks the intake manifold does fit i think because this guy has one on this forum, http://www.scooterinvasion.net/forum/vi ... 775fdcf372
so ill probably be purchasing these 3 things soon
would a keli variator be better for top end than these three things do you think? i dont think it would i just wona see wot other ppl think
thanks
jacob789
Post by jacob789 »
also do those bando high power race coils give you more top end and do you have to buy anything with them?
jacob789
Post by jacob789 »
just tested my top speed and i now hit about 55mph as opposed to 45mph before i got the drive belt changed. later i may get the gear-up kit fitted and possibly hit 60mph hopefully.
Mystic
Post by Mystic »
awesome, it is amazing what a little transmission tuning will do for your speed. 10mph by changing a belt is pretty good :D
jacob789
Post by jacob789 »
i know. do those bando high power race coils give more top end at all?
