my tank
- bitteraspects
i have a spree. it blew up and is still sitting in the basement waiting to be fixed. its just that i dont have a job right now and i cant afford to fix it. althogh i could afford to put the rings in the tank and get it running again. so im gonna just get it running again and drive it around with a for sale sign on it. it auta go fast being driven around
Probably, but be my guest anyway.
I now think that you have a stuck valve, not low compression.
Admin, Hondaspree.net
stuck or bent,or some how the timing got off? chain drive to cam right?
what you need to do, is a leakage test, add air into the cylinder and turn the motor till you have no air coming out the exhuast or intake, if you always have air coming out from 1 then you have a problem with that side valve -intake or exhaust,I think you have a bent valve from over reving the motor when the clutch blew out!
