want to build a trike
Re: want to build a trike
Thanx seanzee...manuals also contained here in WikiSpreedia..... :hi: ...Plus I have hard copy...Gyro S imported '85 &'86....
Majourlittle: Several would benefit from a schematic for Gyro rear wheel adapters. First dimension needed is the bolt pattern/diameter of Gyro S hubs....then the same for the wheels intended for replacing stocks. I can provide stock measurements, but no idea what wheels I would use to replace stocks....most likely an 8" with 4-lug on 4" dia.....( NOT buying wheels from Japan for $200 each)...spacing will also be at issue so adapter thickneess is critical to wheel choice. A basic schematic could be created and then revised for alternate wheel choices. Thanx for any drawings you can provide......... :D :D :D
Majourlittle
Post by Majourlittle »
Lets do it then.
Need diameter of the bolt hole. need diameter of the center hole and need the inside-to-inside measurement of one bolt hole to the center hole.
PM me if you want to get this sorted.
NC-redleg
Post by NC-redleg »
:( That is not my trike,sorry if that was the impression taken,was not my intent.I am working on a Lifan based trike and those are images that I have collected for ideas. The page that I posted has adapters to do that and there is a a guy on Ruckus .com that is working with different ones than stock. It is a simple matter to make a new plate for any existing rim with the proper spacing and offset.Russ
Post by swimmingfree »
look at what this guy did !!! and look at his other vid ..
http://www.youtube.com/watch?feature=pl ... bsMWvhihAs
e-Pirate
Post by e-Pirate »
:3
SWAG
1984 Honda Spree
1985 Honda Gyro S
1977 Honda Camino
1960 Alpa Moor
2009 Piaggio MP3 400
2002 BMW 330xi
