2AB build
- Downsouthdio
Re: 2AB build
Not once did i said it would change my timing.. I said my timing is off.. Head gasket is to lower my 155 lbs of compression
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Re: 2AB build
Do you have a degree wheel? IF not that would be your best bet as far as getting the timing right otherwise its an educated guess
We like to see pics of builds dOOd
- Downsouthdio
Re: 2AB build
Yea i know thts the proper way.. But no i dont so its just going to be a guess like you said.. I havee a bunch of good before and after pics.. Just can someone explain a good way to upload them.. Im on my iphone to
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Re: 2AB build
Sure, get an android.
Anyway you can upload them to imageshack from your phone?
- Downsouthdio
