Jetting down procedure?
Madman
Post by Madman »
Sorry I edited the post I eased the
Clip not the needle leaning out the main! I have no cht yet I'm waiting on delivery! so I noticed the temp went noticeably high when in the pilot range and was popping a lot on take off indicating lean conditions I (think) and it has Run much smoother since jet size was increased in pilot I'll get another photo of plug now!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
bakaracer
Re: Jetting down procedure?
Post by bakaracer »
so where do you have the needle clip now? also did you check compression? your running a 50mm kit now.unless your using high octane race fuel, you better check that compression or KABOOM!!! use carb clean to check for leaks too. you had split that block so spray everywhere along the seams and intake manifold. the ct mani gaskets are known to leak. you wont see oil because its sucking air not blowing.
Madman
Post by Madman »
Plug is Ngk br8hsa
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
bakaracer
Post by bakaracer »
is that a slight whitish ring I see at the base of the porcelain? its lighter than the upper half of the porcelain. is that top part of the porcelain gray or black
veedubh20
Post by veedubh20 »
what is airfuel screw set at?
1 1/2 turn out is rich.
2 1/2 is lean.
get a b8hs plugs.
if the motor pop on the take off. it the pilot jet or grams little to heavy
pop noise is the jets need to be tunes.
pop noise cause the spark plug to foul, just like misfire. make sure the ngk boot cap is flush in good.
need to use 92 gas.
Madman
Post by Madman »
bakaracer wrote:is that a slight whitish ring I see at the base of the porcelain? its lighter than the upper half of the porcelain. is that top part of the porcelain gray or black
Yes slight white ring on base of porcelain top is black. Plug is about 10 min old!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Post by Madman »
I'm going to borrow a mates compression tester today, I'm running. 98 octane 32:1 premix will get gasket paper and replace ct gasket crank case seal is ok must do these I guess before I keep tuning to avoid a kaboom!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Post by Madman »
Ok about 110psi compression.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
bakaracer
Post by bakaracer »
did you use the kick lever? did you kick it till the needle stopped?
Madman
Post by Madman »
Yes and with the throttle open, did not crush the washer!
Ah but I did it with a cold engine! Guess I should do it hot!!
I fail!
New result in the morning!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Post by Madman »
Ok hot engine compression, kick started throttle wide open, didn't crush washer!
About 120 psi
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Post by Madman »
This is the tester I used!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
The long hose is the reason the numbers are so low.
veedubh20
Post by veedubh20 »
the compression is good and fine to me... :2thumbs:
Madman
Post by Madman »
Bear45-70 wrote:The long hose is the reason the numbers are so low.
Thanks bear I think you are right!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
