AF05E Malossi 47 mm BBK installed
tlthehun
Re: AF05E Malossi 47 mm BBK installed
Post by tlthehun »
Peteyparado wrote:Good excuse to by a stroker crank??
Nah, I'm a little sorry that I didn't hold out for a stock cylinder at the beginning of this adventure, would rather be able to ride around with the engine pinned "all day" and not worry about it blowing up, heavier piston, probably higher engine speeds because of the porting, especially don't want to add even higher piston speeds from a stroker crank, compounded further by a shorter connecting rod if that's what they do to compensate for the longer stroke, versus a spacer at the base of the cylinder.
tlthehun
Post by tlthehun »
oem crankshaft 13000-GS7-010 is discontinued according to two Honda dealers. I got hopeful for a minute because it still showed up on Van Wall Powersports' website. :cry:
Meloshameless
Post by Meloshameless »
Graphite 9 can get u a jasil crank for that.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
