Looking for 70cc polini big bore advice
Re: Looking for 70cc polini big bore advice
Nice app spree, you need the dual headset to match hers
scottinscotty wrote:so when your mixing 32:1 your gonna go up on jet size... or if your running 50:1 your going down on jet size to compensate for the lack of or excess of fuel..
wrong!
- scottinscotty
when you change your oil mix ratio you either lean it out or rich it up.. So if you do not want to do that you would either up jet or down jet to compensates
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
