1985 Aero needin some help.
MopedMark
Re: 1985 Aero needin some help.
Post by MopedMark »
I think what you have is a AF16 (94-01 SA50) engine that someone swapped into your aero. They then removed the gears and cover from your original AF05 that came on your aero and put them on the AF16. Like I said from the pictures the following parts appear to be off from a SA50
Intake
Carb
Cooling shrouds
Rear and front rims
Airbox
Kick start
Yes, but the early SA50 Elites also ran an AF05E, as did the SE50 Elites. The engine number needs to be looked up but my source book got stored when I was not looking a month or so ago.
SpamMusubi4Life
Post by SpamMusubi4Life »
Wow you guys REALLY know your stuff. Anything I can check to identify what it really is?
'85 Honda Aero AF16 Corsa
808
ALL
DAY
SpamMusubi4Life
I can take more pics of anything on the motor that you need to see.
808
ALL
DAY
Duke
Post by Duke »
Looks like an AF16 to me. That's a real score man!! :)
87 Elite 50
99 Aprilia SR50 Carb polini
1973 Suzuki TS185 smoker!
2002 KTM Duke
Duke wrote:Looks like an AF16 to me. That's a real score man!! :)
Since when is and AF16 marked AF05?
MopedMark
Post by MopedMark »
As I stated before when they swap gears out of the AF05 into the AF16. Swapping the gears from the AF05 which I think are 10:1 is a cheap upgrade.
MopedMark wrote:Swapping the gears from the AF05 which I think are 10:1 is a cheap upgrade.
Can be reasonable cost, but takes tracking down the correct model. Of all AF05's, only the '87 SE50 got 10.2:1, and only the non-restricted version. The rest of the AF05's are about 11.1:1
Gear table link on 'wiki
Duke
Post by Duke »
Yeah a bit of a Frankenstein but in the best possible way!
87 Elite 50
2002 KTM Duke
SpamMusubi4Life
Alright Im lookin to drop in the 72 polini corsa, $350. I think that price is a little steep but thought I'd ask the pros on if that's the going price or can I snatch one for way cheaper?
808
ALL
DAY
evilone
Post by evilone »
The trans cover that was originally on the motor will verify it's an af16 :roll: .
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
SpamMusubi4Life
What is it?
808
ALL
DAY
SpamMusubi4Life
Bear45-70 wrote:Yes, but the early SA50 Elites also ran an AF05E, as did the SE50 Elites. The engine number needs to be looked up but my source book got stored when I was not looking a month or so ago.
Where is the engine number located?
808
ALL
DAY
paulpauly7
Post by paulpauly7 »
it would appear to be a af16 that has had a af05 gear swap it may well have been done to retain the original engine code that matches the papers rather than a mod for performance
SpamMusubi4Life
So its an af16 with af05 gears n cover you guys say. Also I was trynna figure out why it doesn't pull after about 33 mph. I pulls strong till it hits about 33 and then it just stops, like it runs outta power. Its still screaming but not pulling like it should. Any suggestions?? Its still stock carb but running a #95 jet, also has 9g weights.
808
ALL
DAY
