biggest carb for a spree?
abreen89
Re: biggest carb for a spree?
Post by abreen89 »
bradbutlernc wrote:I would consider buying the CT intake, where do you get it from though?
for the spree the ct intake requires an adapter. Tazland has them but does not sell them separately only as a kit: http://www.ebay.com/itm/Honda-Spree-NQ5 ... 564a512ae5
Maybe if you contacted him he would share the dimensions for the adapter. The ct intake is a 4 bolt setup and the spree is only a 2 his adapter works great!
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
paulpauly7
Post by paulpauly7 »
more than the perfomance you will see. you need to open the cases and open up the intake windows on the block if not your wasteing your time
bradbutlernc
Post by bradbutlernc »
The block and cylinder are being ported, i dont really think with a 19mm ill need an intake though. Porting the stock one should be fine
abreen89
Post by abreen89 »
bradbutlernc wrote:The block and cylinder are being ported, i dont really think with a 19mm ill need an intake though. Porting the stock one should be fine
with the 19mm carb the stock reeds will restrict it.. and it will be a waste.
The CT adaptor is reported to work pretty well, but not sure it's needed for 19mm throat.
Maybe an in-between upgrade to the slightly larger SB50 Elite "E" reeds. Those are truly bolt-on, and with porting and polishing may be more than enough.
