Page 3 of 4
Re: noob wondering what i have
Posted: Sun Oct 28, 2012 7:53 pm
by ss421
So i should measure where the nut screws on???
Posted: Sun Oct 28, 2012 7:57 pm
by eliteguy50
Yes, that is the spot.
Posted: Mon Oct 29, 2012 11:42 am
Exasperating isn't it?
The 16 engine crank uses a 17mm socket on the variator nut. The 05 engine comes off with a 14mm. You don't have to do Maff or calculate the pi value of a circle converted from inches to mm. The pic of the exhaust isn't perfect, but that's an 05 based on that alone.
Posted: Mon Oct 29, 2012 11:55 am
by eliteguy50
Better eyes than I. Trust in what Wheelman says.
Posted: Mon Oct 29, 2012 12:48 pm
by ss421
Ding ding ding a 14 it is lol.....so where can i find a high speed variater for the af05....and is this motor even capable of 60 mph
Posted: Mon Oct 29, 2012 1:03 pm
by eliteguy50
ss421 wrote:Ding ding ding a 14 it is lol.....so where can i find a high speed variater for the af05....and is this motor even capable of 60 mph
Depending on what bore kit you have, yes, it is capable of 60. Swapping in the af16 that it started with will make 60 easier. You have a much larger selection of parts. Larger displacement options.
Posted: Mon Oct 29, 2012 1:07 pm
by eliteguy50
The dio variators will fit the af05. You have to reuse the af05 pulley boss so the variator must be able to use the stock dio boss.
Posted: Mon Oct 29, 2012 1:11 pm
by eliteguy50
Keli (ebay), malossi (RedEFT), polini (ebay and various dealers), oko (VT Cycles), and a ruckus variator (WTB ad on the board, buying from ruckus guys that swapped them out) are all common options. Dont get a ruckus acceleration variator like the KN or similar. If you go ruckus, go OEM or a "speed" variator.
Posted: Mon Oct 29, 2012 1:33 pm
by ss421
Wow that's kinda confusing are these all bolt on or requiring some other modification
Posted: Mon Oct 29, 2012 2:43 pm
by eliteguy50
All except for the ruckus variators, those may require a little grinding. Usually 5 minutes or less with a Dremel will be enough for adequate clearance.
Posted: Mon Oct 29, 2012 3:09 pm
by ss421
Ohhh ok so basically the 05 and 16 use the same variater so when looking just get a dio high speed vari
Posted: Mon Oct 29, 2012 3:20 pm
by eliteguy50
ss421 wrote:Ohhh ok so basically the 05 and 16 use the same variater so when looking just get a dio high speed vari
Basically, the crank shaft diameter is larger on the af16, that is why af05 engines must retain their stock boss. The ramp plate hole will also be bigger on the af16 but the slides will keep it centered. The OD of the af05 and af16 is the same.
Posted: Mon Oct 29, 2012 4:05 pm
by ss421
Now when you say retain there stock boss what does that mean
Posted: Mon Oct 29, 2012 4:38 pm
by eliteguy50
ss421 wrote:Now when you say retain there stock boss what does that mean
The metal tube that centers the pulley on the crankshaft. It is roughly 1.5" long.
Posted: Mon Oct 29, 2012 5:16 pm
by ss421
So its not what the belt rides in,on correct...it goes on the inside of the pulley and that's on the back in the variater
