Page 3 of 4
Posted: Thu Aug 03, 2006 11:27 pm
by se50
Was your flywheel sitting outside at all? :D Looks a little rusty. :D
Posted: Fri Aug 04, 2006 9:06 am
by noiseguy
A lot of them are like that.
We're almost there. The parts look right. If you look around the rim of the flywheel, you should find a little bump of steel that doesn't match the rest. Kind of like a banana stuck to the center tread of a car tire. Take a picture of that part.
Posted: Mon Aug 07, 2006 4:40 pm
by Spirit of 95
Posted: Tue Aug 08, 2006 9:59 am
by Spirit of 95
Posted: Fri Aug 11, 2006 11:41 am
by Spirit of 95
I'm still hoping that someone can help me with my engine problem. I have pictures that are posted and I can provide more if needed.
Still Need Help.
Posted: Fri Aug 11, 2006 1:31 pm
by noiseguy
All the parts look like what should be in there, so I'm stumped. I still think it's a basic running issue; the fact that it putters over backwards is probably one that should be ignored.
Back to basics. You've cleaned the carb; can you see light through the idle jet?
Posted: Fri Aug 11, 2006 2:30 pm
by Spirit of 95
yes you can. I would think that if a jet was clogged....it wouldn't run at all
Posted: Fri Aug 11, 2006 3:53 pm
by zonker1984
a random thought that probably shows my lack of knowledge on how these things work, but could it be that the cylinder started in a weird position, causing it to fire backwards and got stuck like that? Another thought being that someone forced it backwards while the engine was running, forcing a backwards rotation on the cylinders. Again, this is probably showing my inexperience with two-stroke motors, but it happens sometimes on a one-stroke.
Posted: Fri Aug 11, 2006 4:07 pm
by Farfignugin
Not to be a total *, but how exactly does a "one-stroke" engine work??
Posted: Fri Aug 11, 2006 4:42 pm
by se50
Why, it's simple. The piston will be forced down after the fuel is ignited, but will not go back up. It is only useful for brief bursts of power. :D
Maybe, he means, one cylinder. I know, that a model aiplane engine (looks like about 1cc) can be started backwards. In fact, one I have laying around has a feature that makes it not possible to be started backwards. It is also a 2 stroke, but operates like a diesel.
Posted: Fri Aug 11, 2006 7:58 pm
by Farfignugin
yea, almost all nitro modle engines run "like" deasels, and they do have a one-way bearing (nice name for it) to prevent them from running backwards, cause it could happen easily with those.
Posted: Fri Aug 11, 2006 11:06 pm
by zonker1984
Yeah, I meant one cylinder. This is what happens when I try and explain something right after waking up.
Posted: Sat Aug 12, 2006 10:33 pm
by Spirit of 95
Ok...back to the subject. What would control spark timing on a spree?
Posted: Sun Aug 13, 2006 1:22 pm
by noiseguy
Spark timing isn't adjustable. The little metal tab that you took a pic of passes the pickup and ignites the spark. Since you appear to have the stock parts here timing should be fine.
You could check it with a timing light. I'm guessing, at cranking speeds, advance should be anywhere from 5 to 0 deg BTDC.
My Spree engine runs.....BACKWARDS????
Posted: Sun Aug 13, 2006 3:30 pm
by vonchuk
Somebody mentioned in an earlier post that reversing the wires on the pickup would advance the timing. I do not think that should make any difference, but just in case have you traced the wiring to the source.
