polini 72 mini stroker help
JAC3
Re: polini 72 mini stroker help
Post by JAC3 »
kauaikai wrote:
JAC3 wrote:
kauaikai wrote:what speeds you hitting? thinking of putting on mini stroke with my corsa
i hit 65 mph on my phone GPS, stayed at that speed i dont know still slow for me... i think like one full stroker.. and im running pg long.
ahh ok i thought you would be hitting higher then that...i got mines up to 69mph it has alot of power off the line. he wheelies easy and its a sym... jus thought would have more action with da mini
my pipe was holding me back i swapped with my friends pg long copy and hit 72MPH..
my next ill lay down but fricken scary..
kauaikai
Post by kauaikai »
mean!!! * for mines cause its actually another piston. cause i had seize my old one so i jus had get another one and jus honed da bore...if had my original i think it would be better. i like atleast hit 75
sym dd50
corsa scorp
kauaikai
Post by kauaikai »
what temps you hitting? you had match boost and port intake?
sym dd50
corsa scorp
JAC3
Post by JAC3 »
kauaikai wrote:what temps you hitting? you had match boost and port intake?
no the ports all virgin.. temps was at 310-320 WOT..
kingkamehameha
Post by kingkamehameha »
What gears are you running
kauaikai
Post by kauaikai »
Cherry for not being ported... Must be da mini stroke! Throw one scorpion on dat bad boy
sym dd50
corsa scorp
kauaikai
Post by kauaikai »
Cherry for not being ported... Must be da mini stroke! Throw one scorpion on dat bad boy and port um
sym dd50
corsa scorp
JAC3
Post by JAC3 »
kingkamehameha wrote:What gears are you running
8.4:1
kingkamehameha
8.4:1
On a sym?
kauaikai
Post by kauaikai »
8.4:1
On a sym?
i think his is a elite...i get one sym with 7.84
sym dd50
corsa scorp
JAC3
Post by JAC3 »
yeah elite
kingkamehameha
My friend just put together a ministroker nickle sil ported by tru72 and it is the fastest bike around here. Hes a bigger bradda and he still haaaaaama. He had a mini stroker corsa prior and it blows it away
vette76
Post by vette76 »
kingkamehameha wrote:My friend just put together a ministroker nickle sil ported by tru72 and it is the fastest bike around here. Hes a bigger bradda and he still haaaaaama. He had a mini stroker corsa prior and it blows it away
that the one he did a couple weeks ago? i saw it on facebook
87' spree (SOLD
12' wrx
kingkamehameha
Its purple
tru72
Post by tru72 »
:thumbwink:
talked to the big bruddah the other day, he is stoked on the set up!
