1985 spree 40qmb bbk (no more gy6 or blower)
dem0nk1d
Re: 1985 spree gy6 50cc swapped (now with supercharger)
Post by dem0nk1d »
So you're moving to efi then?
"Like I tell people all the time Speed cost money ..if you have to ask how much then most times your not going to do it !" -tru72
--\\\Projects\\--
95 Elite Restore Project for Wife
1982 Honda Passport
2013 Honda PCX 150
jareeb
Post by jareeb »
nope. needs a fuel pump
1985 spree 40qmb swapped w/bbk (in the works)
Spruckus
Post by Spruckus »
i did this back in the day on a lawnmower engine and i just ran the pipe from the supercharger after the carb it worked to pull fuel as i pointed the comp air at the cylinder. unfortunatly we had to run rich untilll the pump made boost enought ot lean it out.. worked well only thin i did wrong was had no relief valve and blew the engine up
jareeb
Post by jareeb »
gave up on the blower. there is just not enough room for it and still get the body panels on. going with a 40qmb big bore build now. hopes to get it in there with close to stock wheel base so i have a wheelie machine! my gy6 engine is for sale if anyone is interested.
