Page 3 of 20
Re: 2000 Mystic Purple Elite build
Posted: Mon Sep 23, 2013 9:51 pm
by cruzingratiot
going back together
Posted: Mon Sep 23, 2013 10:32 pm
by bfowler
Hey just a quick question about your gears. Did you replace washer #11 with washer #9. Meaning you have 2 washer #9s instead of the plastic washer #11? Or did you just use the regular washers that were originally there and had no binding issues (#9 and #11)? Thanks! Builds looking really good!
Posted: Mon Sep 23, 2013 10:47 pm
by cruzingratiot
used original washers plastic & metal
&new trans gasket
trans turns fine no binding
Paul
bfowler wrote:Hey just a quick question about your gears. Did you replace washer #11 with washer #9. Meaning you have 2 washer #9s instead of the plastic washer #11? Or did you just use the regular washers that were originally there and had no binding issues (#9 and #11)? Thanks! Builds looking really good!
Posted: Sun Sep 29, 2013 3:57 pm
by cruzingratiot
its alive
need to rejet carb install air box
install center spring and polini clutch
runs good
right click on pic and (open in new tab) for video
Posted: Sun Sep 29, 2013 8:17 pm
by bfowler
Hey sorry for all the questions. What kind of exhaust gasket are you using? One that came with corsa or a different one?
Posted: Mon Sep 30, 2013 8:05 am
by cruzingratiot
the one that came with the phongeer pipe and a little hi temp sealant
bfowler wrote:Hey sorry for all the questions. What kind of exhaust gasket are you using? One that came with corsa or a different one?
Posted: Mon Sep 30, 2013 1:33 pm
by paulpauly7
im using the standard copper ring that came with the corsa and a little high temp sealer.No leaks at all
Posted: Fri Oct 04, 2013 12:04 am
by cruzingratiot
350 miles on it time for first test
for future reference
93 Octane fuel , (R+M)/2.
8.5 gears
24mm Polini carb 110 main jet 40 pilot jet
yellow contra spring 1500 RPM
variator weights ? forgot to write down 42 grams
Belt original 1800 mile
Humidity:87%
temp 70 deg F
CHT hit 345 deg
65.2 MPH
cruising 35 to 45 mph CHT stays 280 to 295
need a rpm guage
I know I am forgetting somthing
Paul
Posted: Fri Oct 04, 2013 12:08 am
by paulpauly7
nice
Posted: Fri Oct 04, 2013 12:55 am
by bfowler
NICE. very nice! what clutch grabber springs?
Posted: Fri Oct 04, 2013 1:40 am
by paulpauly7
im running 4k springs but the clutch doesnt engage till 5900 .A little bit over the top for street use but hey you have seen my bike i like over the top lol
Posted: Fri Oct 04, 2013 2:38 am
by LMH
Youre going to want to up that main, theres still more life in her, Break her in nice and slowly tho. The polini PWK is a nicer copy of the Keihin but still the same as the OKO in terms of flow etc.
Posted: Fri Oct 04, 2013 6:13 pm
by cruzingratiot
I have the 3 shoe polini adjustable clutch
need a tack to figure out where it is at
about 4 turns in from the stock polini setting
Paul Jug
paulpauly7 wrote:im running 4k springs but the clutch doesnt engage till 5900 .A little bit over the top for street use but hey you have seen my bike i like over the top lol
stull messing with jet sizes had a 120 & 115 it was a little fat but I am go into try again
that was when I had the stock clutch and contra spring
now it has the 1500 yellow and the polini clutch
LoveMyHonda wrote:Youre going to want to up that main, theres still more life in her, Break her in nice and slowly tho. The polini PWK is a nicer copy of the Keihin but still the same as the OKO in terms of flow etc.
Posted: Wed Oct 09, 2013 7:18 pm
by cruzingratiot
450 plus miles running good
Posted: Wed Oct 09, 2013 7:45 pm
by LMH
Such a nice bike!
