Elite wheel,fit spree front forks,with metro brake hub. Yes.
Re: will elite wheel,fit spree front forks,with metro hub br
Hi forum.
After trial and error, cutting and grinding, and a couple hubs later. take a look.
- 20140503_050936[1].jpg (146.49 KiB) Viewed 6611 times
- 20140503_051010[1].jpg (149.9 KiB) Viewed 6611 times
- 20140503_051052[1].jpg (167.39 KiB) Viewed 6611 times
Hi forum.
Your going to have to flatten the inside of the shock tube where the boss go's. just a little with a hammer. make a mark so that you don't hit the shock tube higher than the boss area. try to keep the tube round. your shock is right there and needs to go up and down. you can cut it but that more fabrication.
Measure 2-3 times then drill your hole straight. use a jig saw for final cutout. keep you cuts straight. so your new boss will be straight with the hub.
- 20140503_051506[1].jpg (165.65 KiB) Viewed 6611 times
- 20140503_051802[1].jpg (161.15 KiB) Viewed 6611 times
- 20140503_051916[1].jpg (168.6 KiB) Viewed 6611 times
Hi forum.
Test fit the new boss.
I have two hubs and both fit.
- 20140503_053540[1].jpg (163.98 KiB) Viewed 6611 times
- 20140503_053717[1].jpg (161.48 KiB) Viewed 6611 times
- you can see where I had to grind a little off. to make it fit the forks. don't go too far you will have to get a new hub.
grind a little and test fit, repeat. use a marker as a guide. - 20140505_064932[1].jpg (126.05 KiB) Viewed 6611 times
Hi forum.
Test fit hub and the wheel. tack it in place, with the wheel on the forks. now you know it fits . finish the welds.
- 20140503_054527[1].jpg (117.58 KiB) Viewed 6610 times
- 20140503_062700[1].jpg (115.93 KiB) Viewed 6610 times
- 20140503_063548[1].jpg (159.89 KiB) Viewed 6610 times
Hi forum.
- 20140503_063602[1].jpg (111.64 KiB) Viewed 6610 times
- 20140503_063811[1].jpg (161.78 KiB) Viewed 6610 times
Hi forum.
The brakes work great. a lot better then the spree brakes.
1. metro brake hub, with brakes.
2. 95mm elite wheel 94-01
3. 94-01 axle bolt, spacers.
4. tire size is 2.75-10.
Any bigger tire will rub on the spree forks.
I think I'm going to change them to left side. because Honda made the brakes for left side. and my wheel is facing opposite side.
I have to get a longer cable. but everything works fine.
- 20140503_065319[1].jpg (133.81 KiB) Viewed 6610 times
- 20140504_062848[1].jpg (116.55 KiB) Viewed 6610 times
- 20140504_063520[1].jpg (106.13 KiB) Viewed 6610 times
Hi forum.
There you have it bigger metro brakes on spree forks with elite wheel.
- 20140504_061513[1].jpg (178.83 KiB) Viewed 6609 times
Hi forum.
I had to delete old photos from the other build to post these photos.
If you plan on going with the metro hub, put it on the left side where Honda intended.
I don't think it will make a difference? but the front wheel will match the rear.
You're the first to post this, Ped. Very useful information for Spree owners going 2-3 times faster on a Spree frame than Honda-san ordained.
Thank you wheelman.
Let me posts some WARNINGS!
Brakes are VERY IMPORTANT for stopping. please read the warnings.
WARNING!
1. Please do not try this mod unless you know what your doing.
2. Seek professional help from a shop.
3. Ask your dad for help and advice.
4.Try at your own risk
5.I'm not responsible for any damages
6. Use you head. do not try this if your not sure.
7. Be safe.
WARNING!
7. Be safe.
Cool idea, great execution, and thanks for sharing.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
- swimmingfree
you did a grate job on it nice to see new things on here ...
Nice from start to finish. Good work getting though issues, Thanks ped!
Re: Elite wheel,fit spree front forks,with metro brake hub.
Hi B. I used a 94 and up elite front wheel. the metro brake hub slide into that wheel. I believe the brakes sizes is 95 mm.
the spree front wheel is too small and cannot be used with the met brake shoes.
try to space, and center the elite wheel and metro brake hub on the spree forks, before you cut and weld on the boss. that way there's no binding.
I had to use a hammer to flatten the inside of the spree shock tub a little bit, so the metro hub sit flat. use a magic marker to mark the area you want to flatten just a little. the brakes work great. they stopped just like a elite or metro, after a few miles of brake in. good luck be safe.
- 20150330_185622.jpg (125.14 KiB) Viewed 6534 times
- 20150330_185649.jpg (124.54 KiB) Viewed 6534 times
- 20150330_185703.jpg (131.03 KiB) Viewed 6534 times
- 20150330_185742.jpg (128.09 KiB) Viewed 6534 times
