Daytona Thunder CDI
- paulpauly7
Re: Daytona Thunder CDI
the plugs that mousewheels posted is the same as my niftyfifty(spree) and my dios
- paulpauly7
Well i got the cdi unit .It was plug and play as i thought i went for a ride engine sounds cleaner .It did make a difference not as much as i hoped but i now need to do some trans tuning again .My top speed went up from 69.9 to 71.3 and my rpm went from 11300 ish to 14400 .now at 14400rpm it started to studder a little not sure if thats carb or the cdi but ive never pulled them rpms befor so ill look into it .Between the three settings there was bugger all difference .Sad news i tore the belt to pieces at 53mph luckly i was only 200m from home lol
The 94-96 use the kymco Zx style plug in, I can link a pic to the intermediary harness I built to use elite cdis on kymco zx50s when I get home later. If you can get that style it's near plug and replug and then play.
At 14,400 RPMs your stutter is the port timings overlapping because of the speed.
- paulpauly7
lovemyhonda you mean too much rpm not enough speed ? it sounded as is was just reving out without gainin much spped
Yes it was over revving and past your power band. If you looked at a dyno read out it would show you were maybe making 2 hp or less after 13k due to shorter port durations during the high speeds of the piston. You may be able to rev that high but it doesnt produce the power needed because ports are only open a fraction of the time needed to vent the exhaust or pull it up during scavenge.
- paulpauly7
thanks dude i just spent the last 45mins reading up on it.As said the cdi has made a difference but as the engine characteristics have changed now my trans tuning needs to change .Ill keep you all posted on how it goes.im also gonna change back to a s trans only cause i dont have another zx belt .Im gonna order the malossi zx belt but untill it gets here im back on the strans for now .Ill do a bit of work on it today
That malossi belt is everything you need, it will help you get better speeds and safer. If a belt brakes and gets caught up behind and around the driven pulley and the case it can lock up the rear wheel and tail spin you. Safety and performance in one! Only down side is that kevlar belts wear out components faster.
Heres a pic from afar of one of my progress Racing cdis, Ill root around later for a better pic.
- paulpauly7
im gonna up grade the coil and lead aswell .Might help might not only time will tell .Ill post more later today
I highly recommend the nology hotwire for a set up like yours.
- paulpauly7
now im running the s trans (for now) it needs some roller tuning as my max rpm was 10250 but only touched 60mph .I ran the same run with the daytona in all three settings couldnt notice any difference except on setting 3 my tto rpm guage went crazy giveing all kinda readings.And the same run with the stock cdi it seemed a little flater thru the rev range with the stock.Temps are running same with both cdis
