if i was you i wood do a compression test on the motor as it sit stock .. that way you no what it is then do what ever to the head and test it again to see you have the raze the compression and by how munch ...it will not give you a number like 8/1 but you can see it helps ...
Ethanol conversion
- swimmingfree
Re: Ethanol conversion
