Page 3 of 5
Re: Million Dollar Scooter Build
Posted: Wed Mar 05, 2014 1:58 pm
by Limp1144
Thanks tail light wired correctly. Waiting on exhaust now. What do people think of the oko airbox are they any good two are 115 shipped
Posted: Wed Mar 05, 2014 2:38 pm
by Limp1144
Also i want to keep my jetting down to keep my gas bill down. any recommendations. 24mm, polini corsa, v8 pipe, 7 gram rollers, 9:1 gears
Posted: Wed Mar 05, 2014 6:06 pm
by LMH
Don't go big bore if you want to save gas ha. The 24mm and up carbs are gas hogs and you should use a 19 or 21mm arreche if you're looking for a resolution that still gives performance and conservative fuel use.
Posted: Wed Mar 05, 2014 6:07 pm
by LMH
I've heard good things about the oko air boxes and I think someone on here uses one currently. I've yet to ever try any air boxes.
Posted: Wed Mar 05, 2014 6:19 pm
by Limp1144
I wonder if it makes less noise than the air filter would.
Posted: Wed Mar 05, 2014 6:38 pm
The OKO does little to reduce noise, but the rubber snorkel might improve the intake efficiency. Flash 5 ran faster with the OKO box than with a pod. Unfortunately it's let down by really crappy materials, My snorkel has cracked and all but split at the seam. I wish they sold the snorkel separately.
It's challenging to mount the box without kinking the snorkel. It's also prone to foul the black fender skirt if you run one. I used a heat gun to change the angle of the screw that bolts up to the case behind the shock. Then I got cute with washers and spacers to locate it as well as I could. It does offer a heavier carb a little support from astern.
Posted: Wed Mar 05, 2014 6:52 pm
by Limp1144
Thanks wheelman you just saved me 115.00 thanks again.
Posted: Sun Mar 09, 2014 7:47 pm
by Limp1144
I have never seen a stock bore seized here is the proof that people are idiots
Posted: Sun Mar 09, 2014 7:50 pm
by Limp1144
Posted: Sun Mar 09, 2014 7:54 pm
by Limp1144
Next the big bore install
I sprayed down the cylinder with degreaser to get all machining metal out of the cylinder. I spray it down till the rag comes out clean.
I coated the piston, jug, rod bearing, and piston pin soaked in KLOTZ 2t racing oil. This stuff smells amazing.
Posted: Sat Mar 15, 2014 10:12 am
by Limp1144
Is it Christmas???┬┐┬┐┬┐
So simple a baby could premix
Posted: Mon Mar 17, 2014 6:11 pm
by Limp1144
Posted: Thu Mar 20, 2014 4:02 pm
by Limp1144
No love lately from the forum
Posted: Thu Mar 20, 2014 5:23 pm
by PorterGuy85
Looks sweet
Sent from my SPH-D710VMUB using Tapatalk
Posted: Thu Mar 20, 2014 7:52 pm
by Red Eft Performance
Im watching....
