Low miles 1985 Aero 50 restore
- PorterGuy85
Re: Low miles 1985 Aero 50 restore
Update
- 2014-03-31 08-17-19-331-1.jpg (168.06 KiB) Viewed 10467 times
- PorterGuy85
Re: newbie from Charleston
I'll have to snap a pic of it tomorrow to show condition. Its cracked and missing a medium chunk.Kevinstonge wrote:Looking good! Judging by the aero 50 font on the front plastic it's indeed an 85 nb50m, but you can confirm by the vin tag on the frame behind the front wheel. Be careful not to break or lose the black plastic piece Inbetween the rear blinkers. That oem piece is getting harder and harder to find.
Probably sell it or trade for an air filter??
- PorterGuy85
Found out that the headlight doesn't come on until it's running. I figured that, makes sense.
- PorterGuy85
Another petcock, threads too large. Keep getting spree ones. Anyone have one?
- PorterGuy85
She runs!!! Took a few short bursts with the elec start since thats all it has. Ran for a few short seconds. Airfilter & cover should be here in a few days. Oil to pump is good. Spark is good. I'll post a link to a video asap. Cheers!!
Honda changed the tank fitting diameter in 1986 for ALL models, not just the Spree. The 1985 petcocks don't fit later tanks, and vice-versa. If you have an '85 you must get a 1985 petcock or a later model fuel tank as the '85 petcocks may not be easy to find.
- PorterGuy85
Yeah I understand, I got a new aftermarket one to work today. Thank you.Wheelman-111 wrote:Greetings:
- PorterGuy85
https://youtu.be/lpXlCym1kpI
Quick vid of it trying to start, it will start if I hold throttle down but she putters to get there. And whike doing so, it leaks gas out of top ovetflow tube on carb. I've tried the settings on carb to 1 3/4 th out and 1 1/4 out. Various air filter configurations too.
Haven't had too much time to mess with today
Hope you figure it out soon...
Lookin good!
Lookin good!
'86 Aero 50 (NB50)
'01 Yamaha Jog Nextzone
- PorterGuy85
https://youtu.be/8agEVxH2B8Y
Here's the scoop.
I did research on the bystarter and figured it probably isnt warming up, which im not sure that it is. I did an infrared temp reading & it doesnt change. Maybe it still is. Anyway, checked my green & yellow connections (shown in earlier thread pics) checked the plug wire. And figured id try again this morning to fire up. It started!! No giving it gas or anything.
that was only once. Now ive attached a vid of me starting it but I have to give it gas. It runs, roughly. And bogs. Fuel comes out of carb top overfow.
Also I've attached pics, which might be an issue or not. The exhaust has been dripping a small amount of oil. THIS WAS BEFORE IT EVER RAN. so could it possibly be clogged??
Here's the vid link & pics.
Here's the scoop.
- 2014-04-11 11-18-23-151-1.jpg (147.43 KiB) Viewed 10387 times
- 2014-04-11 11-18-17-279-1.jpg (174.01 KiB) Viewed 10387 times
- PorterGuy85
Just checked my battery. 11.25v
Its on charger now, all this trying drained it
- PorterGuy85
Better video, starts by giving it gas. About 1/2 throttle and runs by holding at 1/2 throttle. As soon as I let go it dies. Still leaks gas while its running.
Smoke looks good though
- PorterGuy85
https://youtu.be/Loc3oAuRZls
A short ride..
https://youtu.be/Se_2Izvb3r8
Starts instantly! !
Gotta pull the plug because shortly after the ride video it bogged down, it would stay idling but any load put on it shut off. Wait a couple mins & it would fire back up. All in all, very pleased
A short ride..
Starts instantly! !
- PorterGuy85
https://youtu.be/EtzgY-7OxK
After a spark plug cleaningÔåæÔåæ
https://youtu.be/7dnHEteed54
ÔåæÔåæDriveway riding, didnt want to go far because after this video I figured i'd hit the road again. Got up to about 25mph & wanted to bog down again. Lol
- PorterGuy85
My 4 stroke 125 3 wheeler gets up to 500┬║ quick
Is this an ok idle temp for the scoot?
- Exhaust temp
- 2014-04-18 02-44-39-164-1.jpg (146.81 KiB) Viewed 10350 times
- Exhaust manifold temp
- 2014-04-18 02-44-34-925-1.jpg (103.32 KiB) Viewed 10350 times
