The PTSG official AF18e spree dio build thread
Re: The PTSG official AF18e spree dio build thread
Wow, that is hot! Looks great man, love the teal. The pipe puts it over the top, which is where it should be.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
- Red Eft Performance
Very nice! The color is excellent!
Red Eft Performance
View products click => Here
- patthesoundguy
Both of my sprees are that colour. Canada only color for 84
WOW! look at that bad a** spree.
- paulpauly7
Nice real nice
I love them pipes i think im gonna have to get one for my next build .Im thinking it needs to come down about a inch in the rear .
- patthesoundguy
I had it dialed in or so o thought, I have to pull the carb I think the float or float valve is sticking or is are stuck. It just doesnt want to revup right and it wants to cough and sputter once in a while. And it used a half tank of fuel in only a mile or 2. Its behaving uber rich no matter how I jet it. Im pretty confident its nothing too difficult. It won't rev any better if I hand choke it or turn the choke on. The temps are also really low. So I'm sure I can fix it. It worked awesome right after I had put in a new plug and plug was wet so all signs point to rich. And reeds are still fine. I have the spare 21mm carb for so I'm good if I need a part for now. Can't wait its so much fun. It goes 30mph at basically idlegraphite9 wrote:Glad to see you got her dialed! You made short work out of it. I haven't seen a single spree that color in oregon. looks great
- patthesoundguy
I can totally drop it an inch I can just drill another hole in my shock relocation bracket its 3" wide plate and its near the edge of itpaulpauly7 wrote:Nice real niceI love them pipes i think im gonna have to get one for my next build .Im thinking it needs to come down about a inch in the rear .
- patthesoundguy
I had a 7 in it then plopped in a 6 to see it worked ffor a bit then gross. I'm just going to pull the carb later when I get home and set the floats up proper and check it all over the needle that was in the carb was really short I'm running the longer one from the 21mm. When it ran right for a bit it had great overall curve I had great ovetal throttle response and bottom end. I had great control it wasn't too light switchy good and smooth. Love the oko carbs so simple to yank em and tune emgraphite9 wrote:patthesoundguy wrote:I had it dialed in or so o thought, I have to pull the carb I think the float or float valve is sticking or is are stuck. It just doesnt want to revup right and it wants to cough and sputter once in a while. And it used a half tank of fuel in only a mile or 2. Its behaving uber rich no matter how I jet it. Im pretty confident its nothing too difficult. It won't rev any better if I hand choke it or turn the choke on. The temps are also really low. So I'm sure I can fix it. It worked awesome right after I had put in a new plug and plug was wet so all signs point to rich. And reeds are still fine. I have the spare 21mm carb for so I'm good if I need a part for now. Can't wait its so much fun. It goes 30mph at basically idlegraphite9 wrote:Glad to see you got her dialed! You made short work out of it. I haven't seen a single spree that color in oregon. looks great
Since you bought that carb used, the floats could be way off. Not sure of your elevation, but your jetting and needle clip are probably too fat aswell. What plug are you running?
Did you compare the emusification tubes between the 21 and 24? I don't know that the 21mm and 24 mix well. I could be wrong but I'd change the tubes or go back to the shorter one. You may be fighting yourself. I have little to zero experience with the 21s but have had a similar experience with wrong needle in the wrong carb. Inability to lean out regardless of jetting after swapping and it cleared right up as soon as I swapped it back and let the engine clear itself.
- Rip_City_Spree
having owned the us 87 model in this color for a couple years. I seriously think I had the only one that color in oregon. and have yet to see another that color in portland. kinda pains me that I even got rid of it. your bike looks great love that pipe. and glad you didnt have to cut into the plastics to much. Well done.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
- patthesoundguy
That panel is from my second spree so that i diddnt cry to cut and in a little.Rip_City_Spree wrote:having owned the us 87 model in this color for a couple years. I seriously think I had the only one that color in oregon. and have yet to see another that color in portland. kinda pains me that I even got rid of it. your bike looks great love that pipe. and glad you didnt have to cut into the plastics to much. Well done.
- patthesoundguy
Hmmmmmmm I'll just pop the original needle back in that carb after I check the guts and test it. Thanks for the tipLoveMyHonda wrote:Did you compare the emusification tubes between the 21 and 24? I don't know that the 21mm and 24 mix well. I could be wrong but I'd change the tubes or go back to the shorter one. You may be fighting yourself. I have little to zero experience with the 21s but have had a similar experience with wrong needle in the wrong carb. Inability to lean out regardless of jetting after swapping and it cleared right up as soon as I swapped it back and let the engine clear itself.
- patthesoundguy
Wholely fecal matter
I got it figured out. I was missing ground for the coil. Out testing I pulled the harness to check the wiring. Crimped a ground wire on and went at least 50mph down the slight hill. Scary but fun. now back to carb tuning.
- patthesoundguy
That little scooter rips hard and gets a lot of looks
especially when you pull up to a bunch of bikers.
- patthesoundguy
Time to order a bad boy rear shock for this scooter. I broke the spree shock
