Scooterswapshop DYNO thread Yasuni C16 pipe~
Re: Scooterswapshop DYNO thread Yasuni C16 pipe~
Is there a reason the stock belt can't be used on the dyno? A direct comparison run between a CVT and a cog belt driven pull on the same engine would at last quantify just how much power is lost to belt slip. I would be surprised if the difference were less than 10%.
deuce217
Post by deuce217 »
Can the variator and clutch just be altered to keep a consistent ratio. Maybe the rear clutch could be tac welded, and the variator could be shimmed into a fixed position?
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
Blocking down the variator so the front pulley is fully closed would keep the ratio from changing, and tell us what the belt is costing in terms of performance with the spring pressing full-tight on the belt...
LMH
Post by LMH »
Slip or snap, it wouldn't be happy.
deuce217
Post by deuce217 »
That makes sense. Ok Brandon, so you ship the pulleys you want to use and Ill do the fab work.
50mm BBK (tai)
V-8 pipe
johnny248
Post by johnny248 »
That is such a good looking pipe. Even if it was just as good as something else, I'd want it simply because it looks so darn good. Can't wait for these.
~UNDER CONSTRUCTiON~
curtis966
Post by curtis966 »
Does the yasuni come with any different silencers? I would really like kevlar
DirtyE
Post by DirtyE »
So the first batch of three is the black can right?
98 Elite
4 strokes are for cars
curtis966
Post by curtis966 »
Awesome!! I'm very intrested but I think I'm gonna wait till after the first batch I wanna hear a little more about the performance first. Where did your chart go btw?
curtis966
Post by curtis966 »
Nevermind I found it lol I guess I thought I read that here in this thread.
Revolutionary
Post by Revolutionary »
I did some measuring and think I have a good idea how to make this work and still use the clutch. I have some sprockets and belt on the way from Gates to see if I can mock this up. I need an extra complete clutch unit if someone has one to donate for research...
graphite9 wrote:spoke with rich @HGT today. This is what he had designed. I need to do the same for the dio. Any talented machinists want to take this project on? Only issue I see is incorporating the kickstart gear..
johnny248
Post by johnny248 »
Do these pipes make so much power because of the expansion pipe design?
DirtyE
Post by DirtyE »
you can see here: http://www.scooterinvasion.net/forum/vi ... .php?t=253 where the c16 falls into the realm of things, just in general.
98 Elite
johnny248
Post by johnny248 »
graphite9 wrote:The expansion chamber, pipe diameter, and lengths all contribute to the amount of power, for that specific cylinder/CC. Not all pipes are created equal, as can be seen on the first post. This yasuni pipe beat out all the other pipes in the scoot-tuning dyno article. Thats why I chose it. You could take an ebay pipe, and put it up against this one, or a windjammer, and the difference would be night and day. Pipes are a HUGE deal on two strokes.
So with the Corsa build that I am sloooowly doing, would you recommend this over one of the other pipes you sell? I was reading some of the for sale stuff you had with all of those Scorpion and other pipes you had built.
Rip_City_Spree
Post by Rip_City_Spree »
And it sounds great! Not to loud but loud enough
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
