1st step on my new project
- AIO MotorSportS
- Goped
Re: 1st step on my new proyect
another step less
- CAM01373.jpg (232.58 KiB) Viewed 9101 times
- CAM01369.jpg (173.34 KiB) Viewed 9101 times
- AIO MotorSportS
- Goped
hi ped,ped wrote:Hi AIO. Do you have a name for that stuff?
what are you building? 72cc?
1- no name,no lebel,no tags,sorry,(a friend give to me, few OZ,s on a Ziploc bag)
2- yes
hi AIO. where can I get a spacer like that?was that pressed on or glued on?
maybe I can use Honda bond to fill the oil pump hole?
your project looks really good.
- AIO MotorSportS
- Goped
ped wrote:hi AIO. where can I get a spacer like that?was that pressed on or glued on?
Any machine shop can make one+loctite primer +red loctite +pressed in.
You can use any metal/alum filler/epoxy ,gas and oil proof+500┬░f res +high heat fiber glass fabric
Thank you.
- AIO MotorSportS
- Goped
DirtyE wrote:This is nice work.
Thanks DirtyE
Hi AIO. so are you going to use 2 seals on the crank? On that side of the case?
- AIO MotorSportS
- Goped
ped wrote:Hi AIO. so are you going to use 2 seals on the crank? On that side of the case?
hi ped
No,just one,why you thinking on two?
- CAM01464.jpg (199.91 KiB) Viewed 8999 times
- AIO MotorSportS
- Goped
Re: 1st step on my new project
hi forum
after a several month I'm back to put some time and money in my project(no money no project)
factory gasket not good
home made gasket good fit flow
- CAM01955-1-1.jpg (232.98 KiB) Viewed 8870 times
- CAM01954~2-1-1-1-1.jpg (222.44 KiB) Viewed 8870 times
very nice work. looks clean.
- AIO MotorSportS
- Goped
Lambretta 50mm air filter
- CAM01971-1-1.jpg (249.74 KiB) Viewed 8841 times
- AIO MotorSportS
- Goped
ped wrote:very nice work. looks clean.
Thanks Sir Ped
- AIO MotorSportS
- Goped
Carb upgrade!
- IMG_20150705_003240.jpg (169.23 KiB) Viewed 8800 times
1man8scoots
We use sudoco at the shop for parts, how much was the carb through them?
