My 1995 Honda Elite SR modded!
Xxbeejay45xx
Re: My 1995 Honda Elite SR modded!
Post by Xxbeejay45xx »
Thank you guys very much for your comments
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
S4Patrick
Post by S4Patrick »
That's one sweet build! This is awesome 100% all-the-way-around!
Love the way the LiveDio headset looks on the Elite body!
Thanks for sharing~!
'92 Super Dio ZX - AF18 Corsa
808EERPS48
Post by 808EERPS48 »
this thing looks wicked a lot of fab work but beautiful
84 Spree dio ready
Youtube me: Go RYAN Pro
True 72cc
70+/F/72
Reppin it for the 2+ class
Eastsydah Rydah Productions
#Handodat
Xxbeejay45xx
Thank you very much for your guys comments. Means a lot!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
DirtyE
Post by DirtyE »
Im going to have to paint my panels. Any advice on how to?
98 Elite
4 strokes are for cars
Xxbeejay45xx
DirtyE wrote:Im going to have to paint my panels. Any advice on how to?
Yes there is plenty ways to go at this, but time is what you will have to sacrifice. I bought my plastics from G9 and it had stickers and funk all over them. I sprayed wd40, goo off, alcohol, and this one stripper worked pretty good called Citristrip at Home Depot paint section. It works wonders even on your paint wheels, case covers. It's just like aircraft stripper but not as smelly. Anyways strip, then sand with 600 grit sand paper for a few hours. Then I got some primer at autozone called rust-oleum automotive filler primer. Sprayed 3 coats of that cause the black is harder to cover. Then waited for 2 days to cure. Now with 1500 grit sand paper I sanded with water, then 2000, then 3000. Wash with soap and let dry. It's all in the preparation stage and became not to touch the clean parts with ur bare hands will leave oil mark and can show through paint. I used an eBay paint gun with a 55 gallon air compressor tank. Also bought paint off of eBay for a $100 all in a kit with instructions called UreKem paints. Adjust the gun according to instructions and spray even coats and let flash before applying more coats. I followed all instructions and end results was pleasing. Take your time and if you are painting outside do not pick a windy day to paint it. Paint is laid thin and not heavy as for the clear coat. You have to spray evenly and more for clear coat to look really glossy but don't over spray. Whole process took 4 days including drying time. Fyi I went to the auto paint shop and they gave me a weird look and ask me how much am I willing to pay for all this. So I guess they wanted and arm or a leg for the work. Good luck
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
DirtyE
Post by DirtyE »
Thanks and good work!
98 Elite
Xxbeejay45xx
New update, took apart my scoot again to install malossi crank, port intake, stage 6 reed cage.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Xxbeejay45xx
Malossi crank, port intake maybe did a bit too much???
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
curtis966
Post by curtis966 »
What size tire do you have on that 10x5? And do you mount your pipe anywhere other then the cylinder head? I'm looking to do a fatty soon was just caught up on where I'll be able to mount the pipe without the ears on the case. Thanks!
1man8scoots
Post by 1man8scoots »
Way too cool, nice rides!
Xxbeejay45xx
curtis966 wrote:What size tire do you have on that 10x5? And do you mount your pipe anywhere other then the cylinder head? I'm looking to do a fatty soon was just caught up on where I'll be able to mount the pipe without the ears on the case. Thanks!
Yes I have a 10x5 offset at 2+2. And 120/70/10 I strecth the tire to fit that rim. It will be tough to get that size on. What I found out was the 130/70/10 will be too tall and will rub the case. Maybe try a 2+3 off set on your wheel. Daytona sells atv wheels that will work with the KN hub I'm thinking you will use. Very tight space back there. Let me know what else you need to know, spent lots of hours and money figuring all parts to fit. Trying to do rear disc set up, working very hard on it. Need to make custom bracket.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Xxbeejay45xx
1man8scoots wrote:Way too cool, nice rides!
Thank you very much sir
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
curtis966
Post by curtis966 »
Rear disc! Your a mad man!! Great work and thanks for the advise. I plan on running a kymco hub with a 10x5 at 3+2 offset and I guess a 120/70/10 lol. Im going to try and get it set up this summer. Thank again and good luck with the rear bro that will be so sick!
Xxbeejay45xx
Aww man thanks for the kind words. Here it is with polini Evo huge air filter, malossi Cdi, kn head studs all from scooterswapshop.com. Thing is a beast now! Power on and off whenever I want it, wot anytime and I can hold it for long time too. So much more happy with it now! Did an hour ride today and took some pictures. Enjoy!!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
