Yamaha jog
Mini_Stroker305
Re: Yamaha jog
Post by Mini_Stroker305 »
rakfint wrote:
Mini_Stroker305 wrote:Nope, 68 mph strong and we can surely prove it
Please come tune mine. Haha
Sorry for Newb questions here. I've got a 93 Jog Motor (50cc) it came with no exhaust so I picked up a random one from craigslist for $40. Bolted up, got noticable gains from the rusty old one I had on prior.
I have a pod air filter with only 1 open end which seems better than the fully open pod I had prior.
I have been playing with needle positions and main jets, best I seem to manage right now is just over 60kmph, which I believe this scoot should manage even stock?
If you are running stock carb, not having stock air box will restrict your speeds. Get one and see how it runs if still a little sluggish adjust rollers to lighter and jet carb. You may need to go bigger or smaller on jets just depends how your bike reacts but most likely it will be an up jet that you need. Start by putting clip back to original position on needle and then work from the beginning. It's just a matter of trial and error from there.
96 Yamaha Jog Next Zone CY50
72cc Polini Evo 2
Ruima 41.4 Teflon ministroke
Yasuni C16
24mm Polini pwk
Malossi 8:1 Primary Gears
Malossi VL14 Reeds
Polini 360 Mani
Jaingwayne transmission
Michelin S1 tires 90/90/10
rakfint
Re: Yamaha jog
Post by rakfint »
Only issue is i can`t run the stock air box even if i wanted to, so im kind of left with jetting & needle position right now. I could change up carb, hack plastics etc to go back to stock air box.
Downsouthdio
Re: Yamaha jog
Post by Downsouthdio »
If you plan on changing your carb,,then dont worry about it..but you are going to keep stock carb,,trim them plastics man..you wont regret having the correct airbox on
Honda super dio
Corsa
26mm
Sparrow
Mini_Stroker305
Re: Yamaha jog
Just an update...pretty sure I can still get a little more out of her :coolcruise:
72cc Polini Evo 2
Yasuni C16
24mm Polini pwk
Malossi VL14 Reeds
Polini 360 Mani
Mini_Stroker305
Re: Yamaha jog
Nice pic of Downsouthdio's Super Dio and my bike :coolcruise:
72cc Polini Evo 2
Yasuni C16
24mm Polini pwk
Malossi VL14 Reeds
Polini 360 Mani
Mini_Stroker305
Re: Yamaha jog
Just installed my new Hoca inner rotor kit nice little upgradee :thumbwink:
72cc Polini Evo 2
Yasuni C16
24mm Polini pwk
Malossi VL14 Reeds
Polini 360 Mani
Mini_Stroker305
Re: Yamaha jog
:coolcruise:
72cc Polini Evo 2
Yasuni C16
24mm Polini pwk
Malossi VL14 Reeds
Polini 360 Mani
Mini_Stroker305
Re: Yamaha jog
:love:
72cc Polini Evo 2
Yasuni C16
24mm Polini pwk
Malossi VL14 Reeds
Polini 360 Mani
Mini_Stroker305
Re: Yamaha jog
(: :geekdance:
72cc Polini Evo 2
Yasuni C16
24mm Polini pwk
Malossi VL14 Reeds
Polini 360 Mani
birdman
Re: Yamaha jog
Post by birdman »
Nice pics of two nice bikes. You been my inspiration to do a naked handle bar on my 1990 Jog (after I put a Zuma front end on it of course).
What kind of improvesments did you see from the Hoca inner rotor ignition kit?
92 Yamaha Jog CY50
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
16 Kawasaki Versys 650
1man8scoots
Re: Yamaha jog
Post by 1man8scoots »
It's going to rock after I'm done with it! Is the ignition on it? I've still yet to look at the engine.
Mini_Stroker305
Re: Yamaha jog
I took off as much weight as possible for shipping purposes so unfortunately no the ignition is not on it, but I will send it to you if necessary :naughty:
72cc Polini Evo 2
Yasuni C16
24mm Polini pwk
Malossi VL14 Reeds
Polini 360 Mani
1man8scoots
Re: Yamaha jog
No need. Just curious to see the hoca in person.
Mini_Stroker305
Re: Yamaha jog
ahh i see, sorry bro if i would have known i would have sent it as well
72cc Polini Evo 2
Yasuni C16
24mm Polini pwk
Malossi VL14 Reeds
Polini 360 Mani
jwhood
Re: Yamaha jog
Post by jwhood »
Anybody seen the rattler 110 cylinder direct fit on the 1peqmf engine
